Website issue
Daydotz
Website issue
I'm having issues with slow loading of http://www.waterstones.com/ or not loading atall   Undecided
Seems to be working now  Shocked
Fixes: 5
Re: Website issue
Loads ok here.
Fixes: 4
Re: Website issue
Seems OK to me, although it does seem to take about three or four seconds to work its way through fetching all the page elements - even when doing a page refresh via my caching http proxy.
Daydotz
Re: Website issue
It seems ok now I could only access it via opera's  inbuilt proxy earlier does seem a little odd
I've ditched the tg582n for a t-plink would it be worth switching the DNS if that even a option on Fibre
It's not the first site I've noticed a issue with  I had problems with tp link as well
Fixes: 5
Re: Website issue
It may be worth trying opendns, you should be able to change the dns setting in the TP-Link.
Opendns settings:
    208.67.222.222
    208.67.220.220
May also be worth trying a different gateway, ie renew the connection in the TP-Link.
You can identify your present gateway here:
http://usertools.plus.net/@gateway/
Daydotz
Re: Website issue
Is DHCP  settings the right place  to change this  ?
ADSL with a netgear DG834  & open DNS was much simpler affair  Wink
Despite this it's playing up again
Fixes: 5
Re: Website issue
Just tried the site again, and for me it's fine going through the main pages. But it is slow to open any page relating to a single book.
If this is what you're seeing too, it could be a data base issue with the site rather than a internet issue.
Fixes: 4
Re: Website issue
I'm seeing the same as npr, waiting time for the main page is about 200ms but the book tab is giving me a waiting time of 3000ms.
have a look at the page loads below. But i wouldn't say it was major slow no.
Fixes: 4
Re: Website issue
An example of www.bbc.co.uk/news I've seen a lot worse from the bbc, waiting time is 77ms at the moment.
Daydotz
Re: Website issue
Quote from: npr
Opendns settings:
    208.67.222.222
    208.67.220.220
I switched to gateway pcl-bng01.b and that solved the issue
