Website issue
- Re: Website issue
Website issue
06-08-2014 5:39 PM
Seems to be working now
Re: Website issue
06-08-2014 5:43 PM
Re: Website issue
06-08-2014 5:52 PM
Re: Website issue
06-08-2014 6:00 PM
I've ditched the tg582n for a t-plink would it be worth switching the DNS if that even a option on Fibre
It's not the first site I've noticed a issue with I had problems with tp link as well
Re: Website issue
06-08-2014 6:15 PM
Opendns settings:
208.67.222.222
208.67.220.220
May also be worth trying a different gateway, ie renew the connection in the TP-Link.
You can identify your present gateway here:
http://usertools.plus.net/@gateway/
Re: Website issue
06-08-2014 6:30 PM
ADSL with a netgear DG834 & open DNS was much simpler affair
Despite this it's playing up again
Re: Website issue
06-08-2014 7:58 PM
If this is what you're seeing too, it could be a data base issue with the site rather than a internet issue.
Re: Website issue
06-08-2014 8:32 PM
have a look at the page loads below. But i wouldn't say it was major slow no.
Re: Website issue
06-08-2014 8:33 PM
Re: Website issue
07-08-2014 1:59 PM
Quote from: npr It may be worth trying opendns, you should be able to change the dns setting in the TP-Link.
Opendns settings:
208.67.222.222
208.67.220.220
I switched to gateway pcl-bng01.b and that solved the issue
