Webmail - down for anyone else?
- Webmail - down for anyone else?
18-01-2008 11:41 AM
Re: Webmail - down for anyone else?
18-01-2008 11:49 AM
18-01-2008 11:53 AM
One minute it will go straight in, the next it either timesout or it takes approx 2-3 minutes to signin and display my webmail.
I have been seeing this for around the last 45 mins.
Andy
18-01-2008 12:16 PM
18-01-2008 12:30 PM
18-01-2008 12:59 PM
18-01-2008 1:31 PM
Andy
18-01-2008 1:37 PM
Then I discovered that if I used Firefox rather than IE I got through with no trouble at all.
Now the difference between the two browsers is that (here at work) IE goes through a MessageLabs proxy (to save us from anything nasty on the net) whereas Firefox doesn't.
18-01-2008 1:43 PM
18-01-2008 1:54 PM
18-01-2008 2:11 PM
I wounder if it is external connectivity, ie Outside PlusNet network.
Some times still go straight through and no problems, then it goes slow, or when Squirrell Mail goes to check for more mail each x minutes, it times out on this on a couple of occaions now.
Andy
18-01-2008 2:43 PM
Yep. I use Firefox and every now and then there are 10-20s period when clicking on CheckMail will not show me my inbox.
SW.
3Mb FTTC
18-01-2008 2:47 PM
Sent you results of tracert from my office to webmail.plus.net if that helps.
SW.
3Mb FTTC
18-01-2008 3:01 PM
We've run a check on the loadbalancers and only 2 of the 4 servers (webmail01 & 02) are currently in service. We've not found anything to suggest a problem but have enabled a third server to see if that improves things.
18-01-2008 4:11 PM
The 3rd server seems to have helped once conneted, but not much when actually trying to access the logon page
Andy
