Webcamera failure.
davidhil
Webcamera failure.
On trying to access your Support Centre 1 web camera I was confronted with a blank screen with the advice I should click on Window and Activity. The following are the last few lines of the information which then appeared.
http://portal.plus.net/webcams/webcamview.html?CAM_IP=84.93.217.139&CAM_TITLE=Customer%20Support%20C...
http://84.93.217.139/axis-cgi/mjpg/video.cgi?1190022301230
I am running an iMac computer with OS X Panther 10.3.9 installed. Can anyone throw any light on this failure as in the past I have had no trouble in accessing Plus Net's web cameras?
Regards,
Davidhil
clockley
Re: Webcamera failure.
I'm not sure why this isnt't working, I have just tried using Firefox and it connects fine...  You can see my ugly mug today!
Hope this helps.
Carl
atbs1
Who's the Lady in Red?
James
The one next to the blonde in blue jumper?
Midnight_Caller
I am getting the message:
Axis ActiveX Camera Control
The AXIS ActiveX Camera Control, which enables you to view live image streams in Microsoft Internet Explorer, could not be registered on your computer.
Wen I go here or Wen I go hereHuh
Midnight_Caller
Thank you James_H that did it.
