Webcam
- Webcam
- « Previous
- 1
- 2
- Next »
Re: Webcam
07-08-2012 11:11 AM
Works fine here, could be you need to update flashplayer or enable / disable hardware acceleration in flash player. Especially if it is with a laptop, which tend to be fussy with flashplayer streams.
FTTP 500 regrade from Tues 28th November
Message 16 of 24
(541 Views)
Re: Webcam
07-08-2012 11:12 AM
Actually looking at it full screen the waves are also a bit jerky which implies that it is a low fps (download speed is about 550kbps)
Message 17 of 24
(541 Views)
Re: Webcam
07-08-2012 11:12 AM
@ReedRichards unless its not truly live and cached, the time is out by 3 minutes
Message 18 of 24
(541 Views)
Re: Webcam
07-08-2012 11:15 AM
Train just went past; I'd agree with Oldjim that any jerkiness is just down to the frame rate of the webcam.
Message 19 of 24
(541 Views)
Re: Webcam
07-08-2012 11:18 AM
@Gus, the time on the webcam clock agrees exactly with the time on my computer.
Or do you mean that train was three minutes late?
Message 20 of 24
(541 Views)
Re: Webcam
07-08-2012 11:19 AM
Quote from: ReedRichards Train just went past; I'd agree with Oldjim that any jerkiness is just down to the frame rate of the webcam.
How do I get It back to being smooth? Other webcams railcam operate are perfectly OK with my Laptop.I do not know how to update flashplayer.The time was correct when I view It.
Message 21 of 24
(541 Views)
Re: Webcam
07-08-2012 1:06 PM
You mean there are more train webcams? Are there timetables as well ?
As for the jerkyness, if lots of people are on the same webcam at once then it will go jerky. The camera owners probably checked it when there was very little load on it.
Message 22 of 24
(541 Views)
Re: Webcam
07-08-2012 1:35 PM
Quote from: BRABUS You mean there are more train webcams? Are there timetables as well ?
Yes there are timetables,go to Railcam.org.uk and click on links.They are not In time order though.Secondly The Dawlish webcam has been like this when there have been 9 people viewing It and 22 people viewing It.
Message 23 of 24
(541 Views)
Re: Webcam
09-08-2012 11:11 AM
Quote from: ReedRichards @Gus, the time on the webcam clock agrees exactly with the time on my computer.
I know (from other threads / posts) that Gus has quite high latency but 3 minutes does seem a little excessive
Call me 'w23'
Message 24 of 24
(541 Views)
- « Previous
- 1
- 2
- Next »
