WebMail error
- WebMail error
WebMail error
23-12-2007 10:36 AM
Logged in to check my emails while away and had no problems with any of my mail boxes but one.
The spam box had over 1800 emails. I set, show all then Toggle All. I then clicked the Delete buttn and after a short while got the error message:
I clicked the Inbox link and all messages still there with the deault setting of 200 at a time shown.
I then toggled each page of 200 one at a time and deleted them. That appeared to work except that, after the last page was deleted, nothing was showing next to the Trash Link and the Inbox still showed 1800+ emails. Clicked on the Inbox link and all emails still showing.
Is this a known error or has something just gone wrong?
Cheers
Quote ERROR:
ERROR: Connection dropped by IMAP server.
Query: COPY 4110:5964 "INBOX.Trash"
Cheers
Forum Moderator and Customer
Message 1 of 4
(1,904 Views)
3 REPLIES 3
Re: WebMail error
23-12-2007 7:12 PM
But it's worked before.
I'll try 100 at a time.
But, what's the point of having a 200 messages view option if you cannot delete them at that rate?
Cheers
Edit: Just reduced display to 100 messages and was able to delete them but there were 22 pages to delete.
Would have been easier if I could have been able to display all and delete all in one go.
Still, at least I don't know have to download possibly 6000 or 7000 messages by the time I get home
Cheers
Message 2 of 4
(566 Views)
Re: WebMail error
23-12-2007 7:47 PM
Mav, are these messages in the 'Spam' folder? If so there is another way to bulk delete them using telnet if you're comfortable with that. This should work even when you're getting the Connection dropped my IMAP server error.
First telnet to the IMAP server:
Next you need to login. Note here that each command needs to start with a separator of some sort followed by a <space>. I don't think it matters too much what you use as the separator however here I've used a dot:
Where $username and $psswd are replaced with your mailbox username and password.
Next list the directories on the server:
You'll see the 'Spam' folder in this list. Now what we'll do is delete it completely:
Now re-create the 'Spam' folder:
Remember to log-out else the above may not work:
Now, when you login to Webmail you should find an empty 'Spam' folder awaiting you.
C:\Users\Bobby>telnet imap.plus.net 143
* OK [CAPABILITY IMAP4rev1 CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFER
ENCES SORT QUOTA] Courier-IMAP ready. Copyright 1998-2005 Double Precision, Inc.
See COPYING for distribution information.
. LOGIN $username $passwd
. OK LOGIN Ok.
. LIST """*"
* LIST (\HasNoChildren) "." "INBOX.Virus"
* LIST (\HasNoChildren) "." "INBOX.Drafts"
* LIST (\HasNoChildren) "." "INBOX.Trash"
* LIST (\HasNoChildren) "." "INBOX.Sent"
* LIST (\HasNoChildren) "." "INBOX.Spam"
* LIST (\Unmarked \HasChildren) "." "INBOX"
. DELETE INBOX.Spam
. OK Folder deleted.
. CREATE INBOX.Spam
. OK "INBOX.Spam" created.
. LOGOUT
* BYE Courier-IMAP server shutting down
. OK LOGOUT completed
Message 3 of 4
(566 Views)
Re: WebMail error
25-01-2008 7:22 PM
How do i go about emptying my spam folder if it is in my mailbox.
i use the command ". LOGIN username+mailbox password" but i keep on getting an error message from the IMAP server.
Thansk
Andy
Thansk
Andy
Message 4 of 4
(566 Views)
