We only get stable internet when plugged direct into test socket
- We only get stable internet when plugged direct in...
11-01-2013 10:07 PM
Constantly our internet has been crashing when plugged into this:
But when we connect the ADSL cable into this:
It's really stable and doesnt crash. Does anyone know what the problem could be?
Re: We only get stable internet when plugged direct into test socket
11-01-2013 10:28 PM
The first check is to plug into the front socket with nothing else plugged in - no phones, no Sky box, etc. - and if you have a monitored alarm is that filtered
If that solves the problem then your wiring may not be the problem
If it doesn't the next thing is to look at your internal wiring.
When you removed the lower front plate how many wires are connected to it and what are the colours. A photo would be nice which you can attach to your post using the Additional Options and Attachments link in the lower left of the posting window
11-01-2013 10:43 PM
11-01-2013 11:00 PM
11-01-2013 11:00 PM
(the orange one)
11-01-2013 11:04 PM
11-01-2013 11:38 PM
However, as the front plate is one of the later ones and has the basic bell wire filter, I expect something else is also amiss.
How many extension sockets do you have? Is the colour of the wires connected to them the same as those at the front faceplate?
Are all the extension sockets dead when the faceplate is removed? What is normally plugged in at the various sockets?
Edit: Are all your extension sockets "Secondary" sockets are shown here ie. none have a yellow (or white) ring capacitor.
12-01-2013 9:01 AM
12-01-2013 9:30 AM
Current setup:
Uptime at (working 12pm-8pm unable to monitor at these times):
(12/01)
09:00 - Faceplate connected, Bell cable removed.
09:30 - Uptime: 0 days, 0:30:01 (0 crashes)
10:30 - Uptime: 0 days, 1:30:01 (0 crashes)
11.30 - Uptime: 0 days, 2:30:01 (0 crashes)
21:00 - UPCOMING
21:30 - UPCOMING
22:00 - UPCOMING
22:30 - UPCOMING
23:00 - UPCOMING
23:30 - UPCOMING
00:00 - UPCOMING
(13/01)
09:00 - UPCOMING
Thank you for assistance.
12-01-2013 10:04 AM
I am surprised that the router didn't come with a decent one.
This one would be better http://www.adslnation.com/products/xf-1e.php
12-01-2013 10:18 AM
12-01-2013 10:23 AM
12-01-2013 11:01 AM
Our telephones don't work when the ADSL is plugged directly into the test socket (You're probably aware).
Telephones are working OK at present and internet seems stable (almost 2hrs in).
12-01-2013 11:19 AM
Have you tried making an outgoing telephone call and more importantly tried ringing your number with your mobile - leave it ringing for a while.
12-01-2013 11:28 AM
