WPS on Router
valart
WPS on Router
After a long wait I received  my mini wireless connector from Sky I have a old Thomson router from when I first joined PN and the directions say that to connect to my broadband I need to press the wps on my router,I just wondered if it is the button on the front of my router that connects me if that is not the case I can use my sky remote and press services and put my password in I hope this is the correct thing to do.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: WPS on Router
Hi valart,
The easiest thing to do here is, as you suggested, to go into the 'Services' section on your Sky box and to type in the Wireless Key manually in there.
I hope you've managed to get connected up Smiley
Chris Pettitt
Cloud Environments Engineer
valart
Re: WPS on Router
Thanks for your reply I have used text on the sky remote do I press that button on it and how do I get the upper case letters
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: WPS on Router
You shouldn't need to use the WPS button at all. There should be some instructions on TV via your Sky Box which explains/shows how to put uppercase characters in.
Chris Pettitt
Fixes: 5
Re: WPS on Router
HI Valart, I did a quick google and found this:
http://helpforum.sky.com/t5/On-Demand-Catch-Up-TV/Sky-Wireless-Connector-Password-to-Virgin-Superhub...
It sounds like if you keep pressing the buttons they will cycle around to lower case.
I hope that helps.
Kelly Dorset
Broadband Service Manager
