WPS on Router
- Re: WPS on Router
WPS on Router
03-12-2013 5:25 PM
After a long wait I received my mini wireless connector from Sky I have a old Thomson router from when I first joined PN and the directions say that to connect to my broadband I need to press the wps on my router,I just wondered if it is the button on the front of my router that connects me if that is not the case I can use my sky remote and press services and put my password in I hope this is the correct thing to do.
Message 1 of 5
(2,233 Views)
4 REPLIES 4
Re: WPS on Router
03-12-2013 8:36 PM
Hi valart,
The easiest thing to do here is, as you suggested, to go into the 'Services' section on your Sky box and to type in the Wireless Key manually in there.
I hope you've managed to get connected up
Message 2 of 5
(865 Views)
Re: WPS on Router
03-12-2013 10:32 PM
Thanks for your reply I have used text on the sky remote do I press that button on it and how do I get the upper case letters
Message 3 of 5
(865 Views)
Re: WPS on Router
06-12-2013 11:47 AM
You shouldn't need to use the WPS button at all. There should be some instructions on TV via your Sky Box which explains/shows how to put uppercase characters in.
Message 4 of 5
(865 Views)
Re: WPS on Router
06-12-2013 11:53 AM
HI Valart, I did a quick google and found this:
http://helpforum.sky.com/t5/On-Demand-Catch-Up-TV/Sky-Wireless-Connector-Password-to-Virgin-Superhub...
It sounds like if you keep pressing the buttons they will cycle around to lower case.
I hope that helps.
I hope that helps.
Kelly Dorset
Ex-Broadband Service Manager
Message 5 of 5
(865 Views)
