WNR1000v3 Interface very, very slow
- Re: WNR1000v3 Interface very, very slow
27-06-2012 11:19 AM
Whenever I log onto my router, it takes ages (several minutes) for the interface to load (although the login screen itself is immediate) . Once loaded, each time I select a different menu option, it is the same.
It never used to be like this, it has started in the last few weeks.
Any suggestions anyone?
Message 1 of 8
(1,668 Views)
7 REPLIES 7
27-06-2012 11:26 AM
If you can get the 'disconnect' button up then I'd suggest using it then about 10 seconds later switch off the power to the router, give it a few minutes before switching back on and see if things have improved.
Call me 'w23'
Message 2 of 8
(821 Views)
27-06-2012 3:01 PM
Do you mean Router Status > Connection Status > Disconnect ?
I can get that up (albeit slowly).
Message 3 of 8
(821 Views)
27-06-2012 3:36 PM
That's the one.
I'm assuming this is on FTTC as I believe this is not an ADSL modem/router so it shouldn't cause a problem just to switch it off but better to 'disconnect' properly (via the interface) first anyway to correctly terminate the PPP session.
Call me 'w23'
Message 4 of 8
(821 Views)
29-06-2012 9:45 PM
Yes, it is on FTTC (sorry, should have said that, my bad).
Thanks, I will try that when I get a mo without someone on the net
Message 5 of 8
(821 Views)
29-06-2012 10:15 PM
Sounds like my house! Best be up at 6AM then!
Call me 'w23'
Message 6 of 8
(821 Views)
29-06-2012 10:19 PM
Oh, have you set fixed DNS servers on the Netgear?
Just a thought but that might reduct the 'build-up of clutter' in the router.
Call me 'w23'
Message 7 of 8
(821 Views)
02-07-2012 10:23 AM
Message 8 of 8
(821 Views)
