WBC Status
gordy
WBC Status
Hi there!
My exchange on the Plusnet Exchange status page is listed as being upgraded for WBC between the 9th and 31st March and I was just wondering whether I would automatically be moved to the new product right away once the exchange is updated or do you manually have to request it?
In case you can't cross reference from forum membership my username is "plopshop". Hehe it's a long story... Actually that's a lie, it's not a long story at all!
Cheers!
Gordy
Fixes: 69
Re: WBC Status
We do place automated bulk orders following an exchange being enabled for WBC but you'd probably get that done quicker by giving us a nudge on the forum after the exchange upgrade.
 Adam Walker
gordy
Re: WBC Status
Oh I just checked on Sam Knows and it's now down as enabled for WBC, are you able to push this through if I give you a nudge then? Wink
Here's hoping my good old version 1 DG834G router holds up! The firmware notes say it should work just fine with ADSL2+...
Re: WBC Status
I've just gone to place an order and unfortunately it looks like our supplier's systems aren't all updated yet. I'll check again today but it may be that we can't order until Monday, I'll keep you posted.
gordy
Re: WBC Status
Much appreciated Matt, thanks!
gordy
Re: WBC Status
Hi there!
I was just wondering if there had been any movement on your systems regarding my exchange being upgraded and whether you are able to place an order to upgrade me to 21CN yet?
Thanks!
jojopillo
Re: WBC Status
Hi gordy,
Looks like it's available now.
[quote=BT Availability Checker]Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 2Mbps; typically the line speed would range between 1.5Mbps and 4Mbps
Would you like me tp place the order for you?
Jojo Smiley
gordy
Re: WBC Status
Yeah that'd be great, thanks! Hopefully it'll get a wee bit more than that cause I sync around 4800 on ADSL1 hehe!
Cheers!
Fixes: 10
Re: WBC Status
I suggest you don't get your hopes up to much. If you currently sync around 4800 I wouldn't expect much of an increase.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
gordy
Re: WBC Status
I don't really mind if it's only a slight increase on the download but I'm hoping I can gain on the upload side of things. Just need to wait and see!
Cheers!
jojopillo
Re: WBC Status
Ok, order placed and confirmation sent via ticket/email Smiley
gordy
Re: WBC Status
Thank you Jojo. What is the normal timescale of these things?
jojopillo
Re: WBC Status
It's due to complete on the 13th Smiley
