WAN to LAN Hub 2
jaystormdj
WAN to LAN Hub 2
i wanna know how to change my wan (4th port) as lan?
8 REPLIES 8
Fixes: 334
Re: WAN to LAN Hub 2
Don't think you can.
Fixes: 457
@jaystormdj
To confirm @jab1 post. It can’t be changed.
jaystormdj
there has to be a way i can use wan like an ethernet connection, it don't make sense other way
jaystormdj
that has to be another way for ethernet to connect
RealAleMadrid
Fixes: 66
@jaystormdj  As two other replies have told you the WAN port cannot be configured to be used as an ethernet LAN connection. Some routers are able to do this but not the Plusnet HUB2
bobpullen
Fixes: 327
@jaystormdj - as others have alluded to, it's not something that can be done locally. The functionality doesn't exist. If you need more LAN ports, then a switch is the way to go.
jaystormdj
would i need to contact plusnet for a new router with 4 ethernet ports and will it be a charge as well?
Fixes: 124
@jaystormdj just buy one of these TP-Link-LS1005G
HTH
