VoIP phone stopped working
mnjufce
I have been using my voip phone for quite some time now and was a happy user. Today, it stopped working (signalling is fine, speech is missing), it seems that something in plusnet is blocking outgoing RTP packets from my phone to the address on the internet.
My firewall is standard on the router and set to off on Plusnet side and didn't change anything in settings in several months.
The same thing happened to my colleague who is also on plusnet.
Is something changed in the bigger network to block outgoing UDP/RTP?
cedlor
Re: VoIP phone stopped working
Seems notice was given earlier in the yera that PN were discontinuing this service?
https://community.plus.net/forum/index.php?topic=140832.0
Fixes: 10
Mine's working fine.
Have you tried a router disconnect/connect to see if it works when you are on a different gateway?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mnjufce
I did try router disconnect/connect, I also tried changing the firewall setting on the plusnet side from none to low...
I am not using plusnet voip, I have a remote worker phone that I connect to companys pbx and has been working fine for years till now.
I do find it strange that UDP/RTP traffic from my internal network is getting blocked.
For the ones that use VoIP as well, which client do you use?
Fixes: 10
I have a VoIP phone (Grandstream GXP1400)
Fixes: 247
Using a tp link phone with sipgate is working fine.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 5
I've got a Yealink phone on a fibre line with a sipgate account, gradwell account and LocalPhone account on it and they all work fine.  I've another line (ADSL this time on a business account) which has 5 Yealink phones on it, all with a Gradwell account registered on it, and they are fine as well.
Phil
Phaeton
Is it no audio or one way audio?
mnjufce
I did some further troubleshooting. My SIP phone works. My H323 phone (remote worker doesn't).
It turns out that when we disable SRTP, it starts working. So, no speech (the phone doesn't send data to the server) is dependent on SRTP and it started happening on Friday for me.
At least, now I have a workaround that is not ideal - no security...
mnjufce
And now SRTP works again... For both colleague and me (we are both on Plusnet and were using SRTP until this incident).
I really wonder what happened. Since the version of the switch in the office didn't change, the only other explanations is plusnet (people with different providers didn't experience SRTP issues).
Big thank you to everybody!
