Vista to Win7 upgrade no IPv6
- Vista to Win7 upgrade no IPv6
16-09-2016 1:24 AM
I just upgraded my system from Vista to win 7 32bit now when i open the Local Area Connection box i notice that the IPv6 connectivity says no internet access. When i had vista installed it ran both the IPv4 and IPv6 , Is this normal ?
Only i would have thought that upgrading to a newer system it would have been the same. I can still connect to the internet OK and i wouldn't notice any difference if i hadn't of checked. Its just bugging me
Re: Vista to Win7 upgrade no IPv6
16-09-2016 8:34 AM
PN still don't support IPv6.
Been looking into it for a very long time.
See
https://community.plus.net/t5/IPv6-Trial/bd-p/IPv6Trial
Broadband Fault Reporting :
Contact/Chat : CHAT service only operational in certain daytime hours.
BT Wholesale Speed Test:
17-09-2016 4:47 PM
I am not 100% certain, but I suspect that what you're referring to is the setting on your network connection that provides(ed) for IPv6 DHCP - which would relate to an internal network running IPv6 rather than your internet connection.
18-09-2016 5:15 PM
You could quite well be right. i must admit i dont know a lot about it.
This is what i see now but when i was running vista the IPv6 was enabled. I dont know if i was using the connection or not, But from what i have read its not even possible i was
