Vista to Win7 upgrade no IPv6
zebedy1967
I just upgraded my system from Vista to win 7 32bit now when i open the Local Area Connection box i notice that the IPv6 connectivity says no internet access. When i had vista installed it ran both the IPv4 and IPv6 , Is this normal ?
Only i would have thought that upgrading to a newer system it would have been the same. I can still connect to the internet OK and i wouldn't notice any difference if i hadn't of checked. Its just bugging me
Gel
Seasoned Pro
Fixes: 13
Re: Vista to Win7 upgrade no IPv6
bin
I am not 100% certain, but I suspect that what you're referring to is the setting on your network connection that provides(ed) for IPv6 DHCP - which would relate to an internal network running IPv6 rather than your internet connection.
zebedy1967
You could quite well be right. i must admit i dont know a lot about it.
This is what i see now but when i was running vista the IPv6 was enabled. I dont know if i was using the connection or not, But from what i have read its not even possible i was
