Vista and pop mailboxes
- Vista and pop mailboxes
12-10-2007 9:36 AM
Does anyone know if there is a problem with vista and sending/receiving to pop mailboxes ie thunderbird or windows mail?
I've just recently upgraded to windows vista and last night decided to try to download my mails from plusnet to a mailbox on my new machine, i ran through the settings ( and have since chacked them at least 10 times ) but i could not receive any mails, kept getting timeout errors ( it never asked me for my password ), but i could actually send mails. I've tried switching the firewall off on my router, disabling mcafee internet security and also windows firewall ( although this has never been switched on ) but still cannot receive any mails...
Is there something else i need to do in vista to allow mails to download?
Any help would be appreciated.
Mick.
Mick.
Message 1 of 4
(1,342 Views)
3 REPLIES 3
Re: Vista and pop mailboxes
12-10-2007 12:33 PM
I have been using Windows Mail for some time now with no problems. Not sure if this helps, but my account settings are:
General: Mail account mail.force9.net/Include this account box is ticked.
Servers: My server requires authentication box is ticked
Connection: greyed out.
Advanced: Nothing is ticked.
As I am using AVG the POP3/SMTP settings are 127.0.0.1
Message 2 of 4
(353 Views)
12-10-2007 12:40 PM
It's probably worth checking your settings match those at this page.
Message 3 of 4
(353 Views)
13-10-2007 8:27 AM
Thanks for the reply guy's, as i stated i had checked the settings numerous times, and these were correct, but i have now got it working, i actually uninstalled Mcafee and then it worked??? maybe the disable firewall feature doesn't work....god knows? but anyway, then there was a problem it took about 10 seconds to download each message, but i fixed this by disabling remote differential compression in control panel/programs and features/Turn windows features on or off... ( Just incase anyone else has the same problem )
But now onto my next and potentially worst problem..... I had set thunderbird to delete all mails on the server imediately..... so i downloaded all mails approx 400 into thunderbird, shutdown, then went back into thunderbird, and the mails aren't there....... at this point i started to panic a little ( well a lot to be honest )
is there any way to get these mails back? surely you have a backup and can restore emails?
I'm going to raise a ticket but thought I'd ask here also.
Cheers,
Mick.
Cheers,
Mick.
Message 4 of 4
(353 Views)
