Vista and Thomson
- Vista and Thomson
Vista and Thomson
14-01-2011 5:35 PM
Re: Vista and Thomson
14-01-2011 5:42 PM
i to am running vista on my laptop, was told to change my wireless settings on the thomson gateway, i have changed it to channel 2 and fingers crossed it seems to be ok at the moment.
14-01-2011 5:49 PM
14-01-2011 6:01 PM
14-01-2011 6:05 PM
Quote from: neophyte I don't understand what you mean by 'gateway' and 'channel 2'.
'Gateway' means router
'Channel 2' is the wireless channel number. There are 13 wireless channels numbered 1 to 13.
But there is nothing magical about channel 2 - I guess it was just a different channel to the one ross1127 was using before. There is absolutely nothing wrong with Vista and wireless connections but there is something wrong with the routers Plusnet have been sending out recently - they need a firmware update to fix it. What model do you have, Neophyte?
15-01-2011 12:41 PM
15-01-2011 4:16 PM
http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
[Moderator's note by Jim (Oldjim) the smiley was too close to the end of the link ]
15-01-2011 4:20 PM
15-01-2011 6:23 PM
Quote from: neophyte I've looked at the download link but am a trifle daunted by it. Does it work?
Yes, and the firmware update works for problematic PC wireless connections as well as "certain Apple computers". There is no guarantee it will fix your particular problem but it has to be worth a try.
Quote from: neophyte Should I do this on my main laptop or the one that's giving me trouble?
It doesn't matter, the computer is just a conduit and is not changed itself. Only the embedded software ("firmware") on the router is changed. Either way you need to use a cable connection to apply the firmware update.
15-01-2011 9:59 PM
I later tried another Acer laptop (same model number as my daughter's but an older version with a different wireless card - same type of Intel card as in my Dell laptop incidentally), this had the same problem.
The Desktop and my Dell laptop are Windows 7, the netbook is XP, the two troublesome Acer Laptops are both Vista.
When I first set up the router I switched the security to WPA2 only as this is how I have set previous routers. I have just changed this back to WPA+WPA2 and both Acer laptops then connected, is yours set to WPA2 only?
15-01-2011 10:29 PM
16-01-2011 12:14 AM
The registry key referred to is possibly that mentioned in Microsoft Knowledge Base article 928233.
If help is needed to determine the appropriate {GUID} entry this article might help.
The KB article says that in Windows 7 the registry key DhcpConnEnableBcastFlagToggle is set to 1 by default, so computers with that operating system should not exhibit the 'local access only' problem.
16-01-2011 8:08 AM
Edit: To clarify, this PC had connected without problems to two other routers before the Thomson 585v8 came along so although spraxyt's registry fix might work, it is fixing a problem that is specific to this particular router and which can also be fixed by updating the router firmware..
16-01-2011 9:53 AM
16-01-2011 1:20 PM
Quote from: walker23 I'll probably do both.
It would be interesting to see if the registry change fixes the problem with the version 8.2.7.7 firmware because that would pinpoint what is wrong with that particular firmware (for Vista PC's at least).
