Virus
framar
Virus
Apologies if this is in the wrong place. I have a virus Win32/Cryptor which is messing up the system. Has anyone any advice how I can get rid of it?
thanks. My technical skills are nil!!
1 REPLY
James
Re: Virus
http://www.precisesecurity.com/blogs/2008/10/28/win32cryptor/
Looks like you should be able to get rid of it by starting up your computer in "Safe Mode" and getting AVG to remove it.
