Virging 50Mbps... where's PlusNet's response to this service?
tslock
So Virgin are now offering a 50Mbps package, This is all very tempting. Currently PlusNet seem to be somewhat behind on the speed provided what with Vigin offering 50Mbps and Be offering 24Mbps. I'm very tempted to move.
BUT I'd like to stay to be honest. But only if there is similar service coming very soon in the future (Less than 4 months).
8Mbps just seems so slow now for todays standards. Tbh even 50Mbps is poor but it's as good as it gets.
Is there any news of a new super fast package and the date for it's release (atleast 24Mbps).
32 REPLIES 32
Oldjim
Resting Legend
Fixes: 63
Re: Virging 50Mbps... where's PlusNet's response to this service?
Read the threads in this section and you will have a better idea http://community.plus.net/forum/index.php/board,62.0.html
Note that you would only get the highest speeds if you live very close to the exchange also it depends on when your exchange is 21CN enabled (mine is over a year away). but a 4 month timescale is most unlikely unless you sign up for the trial.
Be3G
Well, firstly, bear in mind that Virgin's service is a completely different kettle of fish, as it uses cable (essentially, fibre to the cabinet) which Plusnet have absolutely no access to as they resell BT Wholesale's products. However, Plusnet are currently trialling ADSL2+, which is what Be use to provide their speeds of up to 24Mb/s. If you want to read more information, plenty can be found in the 21CN forum. If your exchange is enabled thus allowing you to enter the trial, you'll then have parity with speeds you'd achieve on Be - though note that whether on Plusnet or Be, speeds achieved are likely to be considerably less than 24Mb/s.
itsme
Virgin 50mb and Be/O2 24mb are not available in my area but BT will be updating my exchange end of March so I could be getting up to 24mb faster with PN than Be.
tslock
Hum this has raised and interesting question in my head. Future wise does this mean Virgin are likly to surge ahead with it's speed to 100Mbps and above far quicker than PlusNet/BT will.
When will ADSL reach 50Mbps? Or won't it  Undecided
tslock
To update with my Exchange info.
Be = Yes
Virgin = Yes
21CN PSTN switchover target = Q2 2009
I'm 1 mile from my Exchange.
VileReynard
Fixes: 20
ADSL2+ is likely to give a moderate increase in speed, but nowhere near 24Mb/s.
Maybe 10Mb/s - but it's guesswork really.
If you live about 3 yards from the exchange you would achieve 20+Mb/s  Smiley
HPsauce
Quote from: axisofevil
Hmmmmmm. Roll_eyes
I live just over 1km from the exchange by road. My current ADSL2+ sync speeds are:
Downstream        Upstream
  20542 kbps         1390 kbps
Line Attenuation   21.0 db/11.5 db
(that attenuation suggests my line is 1.5km long, i.e. almost 1 mile)
VileReynard
Fixes: 20
Quote from: HPsauce
Downstream        Upstream
By comparison (ADSL2+)
 Downstream        Upstream
  8647 kbps        1168 kbps
Line Attenuation  27.5 db/11.5 db
I don't know what the attenuation suggests, but the road distance is about
2 - 3Km.
HPsauce
Attenuation 27.5dB suggests a 2km line, so very direct!
And attainable download sync speeds of about 17mbps.
So you're either being capped or have significant wiring/interference problems.
MauriceC
Resting Legend
Fixes: 17
Quote from: tslock
Be = Yes
Virgin = Yes
Yes!  But the Virgin 50Meg service is a very different animal delivered via their Fibre to the Curb (FTTC) distribution network also used for Cable TV and goes nowhere near the BT Exchange.
Currently only available in a limited number of Urban areas.  Build out of distribution to other areas is very costly and unlikely to produce a financial return (HINT:  It aint gonna happen).  If you live in one of these areas - great Cheesy
Maurice
Be3G
I should also point out that the 21CN PSTN switchover target isn't the one that's important here, as that's for the telephone service. What's needed is the 21CN WBC date, which can be found from http://users.plus.net/exchanges.
jelv
Fixes: 10
Quote from: tslock
Don't forget that the speed of the connection between you and the exchange isn't the whole story. You might be connected at 50MB to the exchange, but if there isn't enough capacity between the exchange and the rest of the internet you could still be crawling along at sub 8MB speeds at peak times.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mal0z
When I enquired of Virgin about installing digital TV and this fast broadband service - on behalf of a friend - we were told that although fibre ran down the street, in wasn't put into all the properties ( a block of flats in a big city ) and that all we could get was the old analogue cable TV. Even though the adjoining properties had digital - we were told that they could not provide it in the foreseeable future.
So it looks like they are not even investing in short fibre feeds.
So check with Virgins website for availability.
Maybe they know something that isn't public yet about other investment plans for fibre to every property ???.
pierre_pierre
also just reading and P2P is throttled on that service and Virgin has threatened to do the same with iPlayer
