VirginMedia a JOKE!
- VirginMedia a JOKE!
Re: VirginMedia a JOKE!
05-04-2009 2:03 AM
Quote from: ASBO with abit of torrent running on my line at same time
My pings make yours look like WARP FACTOR 9
Not long to go now!
05-04-2009 2:12 AM
05-04-2009 2:37 AM
I have a NETGEAR DG834GT and the PlusNet supplied THOMSON TG585v7
The Question is which one to use for the 10 Day training?
My thoughts are to use the NETGEAR but does anyone here think I may be better off using the THOMSON?
Jameseh, any thoughts on this?
05-04-2009 2:45 AM
no point hooking an un tested router up to your line when its training as it might be faulty and lower the fault threshold on your line meaning BTw will be a pig if you have a line fault down the line
i think jameseh will be doing his weight lifting training till Monday morning now grudkin
time to put a horror movie on
gd luck with the migration on Monday
05-04-2009 3:25 AM
Quote from: ASBO as your syncing the best you can on adsl max i would stick with the setup you have now for the 10 day training( if there is one. does VM use BTw or are they LLU?) after the 10 days is up i would then have a play with speedtouch to see if it offers anything the netgear dosent.
VM use BTw. In fact when I rang them for my MAC they told me that "thier speed problems are due to BTw, and that I would experience the same problems from any other ISP on a BTw package as all ISP's using BTw have the same speed issues that Virgin Media have!"
A ticket was raised internaly by PN due to some problem last sunday that said "This is an ISP Migration Regrade account i.e the customer has requested the account to be regraded to the fastest speed the line can handle after the migration is complete."
The order has since gone through but from the information given there I would think the 10 day training does apply.
Quote no point hooking an un tested router up to your line when its training as it might be faulty and lower the fault theshold on your line meaning BTw will be a pig if you have a line fault down the line
Already tested it! 8128 sync and seemed to be stable.
05-04-2009 3:38 AM
05-04-2009 12:51 PM
Quote VM use BTw. In fact when I rang them for my MAC they told me that "their speed problems are due to BTw, and that I would experience the same problems from any other ISP on a BTw package as all ISP's using BTw have the same speed issues that Virgin Media have!"
to 100% know VM are talking a load bull manure check your exchanges vp capacity history
http://usertools.plus.net/exchanges/
to see more of the history of your exchange add ( &full=1 ) to the end off the address.
example of my exchange
http://usertools.plus.net/exchanges/?exchange=Chesterfield&exact=223&plugin=vp normal vp history address
http://usertools.plus.net/exchanges/?exchange=Chesterfield&exact=223&plugin=vp&full=1 full history address
Quote Well with your line stats unless you've spilt coffee/tea/beer etc over one of them, I don't suppose it'll matter which you use
with that said i will opt for the OP to use speedtouch as the OP can learn everything about the PN firmware speedtouch and advice others when they have problems with it.
broadcom chip till i die me. unless of cause my line length was halfed in length
05-04-2009 1:19 PM
What Chipset does the 585v7 use anyway?
Still undecided which to go with yet
05-04-2009 2:21 PM
05-04-2009 2:38 PM
But other sources say Broadcom.
adie:quote
06-04-2009 3:06 AM
06-04-2009 9:11 AM
Quote from: Anotherone You might have misunderstood that,
Oops, you're right!
I will have to learn to read a little slower!
06-04-2009 8:17 PM
07-04-2009 1:01 AM
07-04-2009 1:15 AM
Quote from: ASBO if your a gamer and want that ping lowering some more raise a ticket to have interleaving turned off.
At Least I get upto 8M
I will after the training period!
Looks very good so far, downloads at over 6Mbps at 8pm can only be a dream on VM!
