View my usage - why only 2 months ?
- View my usage - why only 2 months ?
27-11-2007 9:31 PM
Re: View my usage - why only 2 months ?
28-11-2007 9:19 AM
I'm afraid that this is something that we just don't do and never have done so.
I don't know of a technical reason, but I suspect that it may be storage related.
28-11-2007 9:52 AM
It would be really helpful for allowing the customer to choose the most appropriate data limit in their BBYW package.
28-11-2007 9:57 AM
I'll see if I can find anything out, but I imagine it won't be a quick fix because of priorities.
28-11-2007 11:10 AM
If you can add this into PUGIT then you can add this as an item for other customers to vote on. From that we can then prioritise the work accordingly.
28-11-2007 11:21 AM
While I realise you don't have access to data prior to this within your internal systems, I just wonder whether this information is kept and archived off somewhere or is it simply disposed of?
I guess if it's kept then the work required would be less?
28-11-2007 11:35 AM
Comments can be made in this thread on the Usergroup forum
NOTE: If you go to the PUGIT thread to record your vote - don't forget to fill in your VISP details under the 'prefs' tab!
MauriceC
28-11-2007 11:46 AM
I followed the link but was told that I had already voted ! Can PN computers read minds ? How can I find out how I (and others) voted ?
28-11-2007 11:48 AM
If you click on the "Pref" link in the centre towards the top of that page, you will see a space to enter your vISP username and select one of the above from a drop down box. You should then be able to vote.
Phil
28-11-2007 11:49 AM
28-11-2007 12:57 PM
Quote from: eugeneg How can I find out how I (and others) voted ?
Your vote for this was recorded at 11:41. After you vote the 'you can vote here' message changes to 'you have already voted' which, it is agreed, is confusing as a response to a new vote. Forum members cannot see individual votes, just confirmation of their own and the total cast.
There are a number of issues associated with vote recording of which that is one. Another is mentioned in PUGIT 257 that might be of interest.
28-11-2007 1:18 PM
I checked my prefs and they look ok
Edit: .....maybe I do having had another look
I gather it's a click to vote yes or don't click at all and go away.
I was expecting a Poll like vote 'Yes or No'
Sorry....it's a silver hair thing
28-11-2007 1:48 PM
28-11-2007 1:51 PM
28-11-2007 2:22 PM
The whole PNUG Campaigns and voting is, IMHO, a mess. I spent half an hour this morning trying to find my way around and understand what is where. As for the last 22 years I have earned a living fixing computers I believe I am no less savvy than the average punter. And surely it is that regular Joe who should be encouraged to voice an opinion. That will only happen if it is easy enough to do within a few minutes.
It is curious that there is no indication that a vote for a particular account has been recorded. I know this is the topic of another thread. I also understand the privacy issues (although I don't subscribe to the view that votes need be private). How about a check box in the preferences to allow a voter to show/hide their vote to others ?
And the whole idea of simply voting or not is arcane. Not only do I want the opportunity of expressing an opinion in favour of an idea, but also my disfavour of it, and currently there is no way to distinguish between apathetic non-votes and a negative opinion.
Moreover, why not allow more than two views ? How about a poll with multiple answers e.g. How long should the usage history be recorded for ? 2 months, 6 months....
The VC column (I assume that means votes cast) indicates how hard it is for average people (a.k.a. customers) to locate and understand an issue. Sure there should be a techie based back end to the system to enable change control, but that needs be separate and in a different language. Simple users need easy to follow UIs that don't require a TLA dictionary to follow and can be understood and navigated at a glance.
I also suggest that simply voting for each item in isolation is of less help than giving the voter a way to express their priority of one idea over another. I may as well vote for everything as almost all the ideas I saw were good, but the folks who have to decide which projects to take up need to know how many of the (potential) customers agree with a particular point relative to a different one. They can then determine the amount of effort required to each and issue a work directive accordingly.
</rant>
