View my usage still broken?
plustrev
Hi, is there still a problem with "view my usage".
I have not had a problem until my month changed over on 10th March, and now I can see no usage.
I find this very useful as I am on a 10gb limit so check it fairly often.
Thanks for any help.
5 REPLIES 5
Legend
Fixes: 255
Re: View my usage still broken?
As you are still on a limited package, it SHOULD show for you.
@Chris or any PN staff?
HarryB
Fixes: 256
Hi @plustrev,
Although I believe there is still a problem displaying usage, this should only affect customers on unlimited usage packages, so I believe the problem on yours isn't the same.
It looks like you connection has been up for quite some time. Could you try disconnecting the router for a little while as this usually fixes the usage not recording on capped accounts.
I hope this helps.
 Harry Beesley
MauriceC
Resting Legend
Fixes: 17
Mine hasn't worked reliably for some long time.  Tried over the last few days but nothing reported!
plustrev
Followed HarryB's advice and view my usage now working. Thanks to all.
Anoush
Aspiring Hero
Fixes: 139
Fantastic news, thanks for letting us know.
If there's anything further/else we can help with please feel free to get back in touch.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
