View My Broadband Usage
praethon
Is there a problem with this at the moment. I've not been able to get any stats since 04/08?
mjtuohy
Re: View My Broadband Usage
Ok here
praethon
I initially thought it was tied in with my regrading. But it has worked since then so I'm not so sure now!  Undecided
mjtuohy
I expect it just took a while for + to sort out the details of your new A/C. Pleased it's ok now.
praethon
Sorry my last post was a little misleading. The VMBU has worked since I was regraded, but only until 04/08. Since then all I get is the error message. Can someone at PN shed any light? Username same as forum name.
Mand
I've passed a ticket through to our networks team to investigate this for you. I've not seen any other reports, but I'm sure they will be able to shed some light on things for you.
praethon
Thanks Mand. That was a lightening quick response by the way!  Grin
praethon
Mand, further to your phone call I have now switched from the RIN back to the normal PN network. Hopefully now the VMBU should appear. I'll have another look tonight to confirm. Thanks again for all your help with this.  Grin
Stuart
Mand
No problem at all, happy to help. Smiley
I've removed the RIN component now, and you should see usage within a few hours.
