Very-very-very slow speed
BiAndSpy
I am signed up for 5-7 Mbps. I am getting 0.16 Mbps downstream and .448 Mbps upstream. I have done all the usual checks, could some nice Plusnet person check my line?
8 REPLIES 8
MatthewWheeler
Fixes: 480
Re: Very-very-very slow speed
Sorry to hear your speeds are poor.
Can you raise a fault here so we can investigate further?
 Matthew Wheeler
BiAndSpy
I have tried reporting but the rely I get is "because you've said your broadband is working, we're closing the ticket...."
The broadband is working and was working before, that is not the issue, my problem is the speed is desperately slow, which the trouble shooter is incapable of recognising. I think that I am correct that to run the trouble shooter broadband is required anyway so it is very annoying that it keeps reporting that everything is fine when their is obviously a problem.
BiAndSpy
Broadband Troubleshooter needs troubleshooting!!
Am I correct in saying that you need broadband to run the troubleshooter?
The reason I ask is that when you try to report a slow connection it asks whether the broadband is working. Surely the answer always has to be yes otherwise it is impossible to run the troubleshooter?
And when entering "yes" the troubleshooter replies that it will close the ticket as everything is working.
So how do you use the troubleshooter to report a slow line?
BiAndSpy
Acceptable range of speeds (Mbps) question
Why do BT acceptable range of speeds seem so low?
My BT speed test reports a download speed of 0.13 Mbps. It also states the acceptable range of speeds is 0.05 to 0.25 Mbps. So BT states my connection speed is fine. I pay Plusnet for 5 to 7 Mbps, so if BT says my 0.13 Mbps is within tolerance, does this mean my on-going problems are not with the BT connection but are with Plusnet?
MatthewWheeler
Fixes: 480
Have you gone down the speed route as shown below?
 Matthew Wheeler
Mav
Fixes: 515
Moderator's note:
Threads merged.
Forum Moderator and Customer
BiAndSpy
Yes I have tried that and the troubleshooter then asks if the broadband works, which is then when I answer yes....but I now know that I should answer no (even though it is working but dead slow).
MatthewWheeler
Fixes: 480
I'll get that picked up for you shortly.
 Matthew Wheeler
