Very unhappy with the service I have been provided lately
- Very unhappy with the service I have been provided...
Re: Very unhappy with the service I have been provided lately
01-09-2014 8:16 PM
01-09-2014 8:46 PM
02-09-2014 9:25 AM
02-09-2014 9:53 AM
02-09-2014 9:59 AM
Quote from: Leds First disconnect of the day, thanks to a phone call.
this sounds like a filter issue, and if you have an in-line filter on the faceplate then faulty faceplate.
02-09-2014 10:01 AM
Quote from: chenks76 this sounds like a filter issue, and if you have an in-line filter on the faceplate then faulty faceplate.
It's not this, as we had the same problem before with 4 different micro filters plugged into the test sockets.
02-09-2014 10:05 AM
if you have a fault ticket raised already i suggest you phone up the faults team to progress it there.
02-09-2014 10:08 AM
02-09-2014 10:24 AM
Are you able to confirm if the removal of the telephone and being plugged into the master socket eliminates the issue? I see you mentioned that you were plugged into the test socket however you also mentioned a call dropped the connection again so I just need some clarity on this one before I give the fault a nudge.
Quote from: Adam Are you able to test the connection from the master socket with all other devices unplugged from any other telephone socket in the house and see if the connection remains stable over the course of an hour or more if possible? Once you've done this if you can let us know and I'll get the fault pushed back through for you.
Considering that the faults tests can see a problem but this is shown internal to your home, we need to make sure we cover all bases and investigate your internal devices/set up before we progress this with the wholesaler.
02-09-2014 10:35 AM
02-09-2014 10:48 AM
I don't mean to sound rude but all of the simple test have been carried out (changing all cables, different routers, microfilters, test sockets, faceplates, quiet line(sometimes quiet, other times not))
02-09-2014 10:54 AM
so you flat refusal to do those tests again is not helpful at all.
if an engineer comes out and the fault is found to be internal then you will be liable for the cost of the engineer visit.
for your own sake you should do that tests again so that it can be clearly seen that you have done what you have been asked to do by PN.
of course, if you know best (and it does seem that) then clearly there is nothing anyone can do here to help you.
02-09-2014 11:27 AM
If knowing best means that I know what tests need to be carried out and that I have done them, then yes I guess I do know best.
02-09-2014 1:56 PM
System Up Time 04:19:59 Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN PPPoA 1890 1515 0 4023 3756 00:02:26 LAN 100M/Full 0 0 0 0 0 04:19:42 WLAN 11M/54M 600698 449540 0 46184 2459 04:19:59 |
02-09-2014 2:41 PM
Quote from: Leds I have had complaints of background noise on the phone line.
You haven't answered the question I posed regarding noise on the line when the filter and router are not connected.
