Very strange problem...
tension83
I have PlusNet fibre.  Connection apparently dropped this morning. Reset all networking equipment,  connection works again, but drops after about 5 minutes.
When connection drops I noticed I am still able to ping plus.net, and Google on 8.8.8.8 but everything else returns 'destination host unreachable'. VDSL sync never drops out and the line is fine.
Can go to plus.net, but no other web pages.
My account is not in arrears.
Can anyone help?
tension83
Re: Very strange problem...
Spoke to billing and tech support several times today.
They said everything looks fine as far as they can see...
Fixes: 190
I've had a quick look over and there's definitely something wrong.
Let me poke a few things here and there and as soon as I'm done I'll drop a reply on here
 Matthew Wheeler
tension83
Thanks very much!!
Fixes: 190
Right poking has been done and this should resolve your issue
If you log into your router and disconnect then reconnect the connection or reboot the router you should be okay.
Do let us know if you're still having issues
 Matthew Wheeler
tension83
Legendary.  Thanks very much mate!!
