Very slow upload
rmacaulay1979
Very slow upload
When running speed test, usually getting okay download speeds but very slow, sometimes zero, upload speed. Can't even stream video.
Shep41
Re: Very slow upload
Can you give us a bit more information.
What are your router stats showing?
This can be accessed on the plusnet hub one by typing 192.168.1.1
Shep41
What fibre package are you on as this can make a big difference to upload speeds
There are 2 packages available at the moment a 40/2 package and 80/20
Browni
Aspiring Hero
Fixes: 45
The Hub One's default IP Address is 192.168.1.254
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Shep41
Whoops. My mistake..... I only aim to be 100% perfect 99% of the time 😂. It's been a long nightshift
Fixes: 162
Can you let us know if you're still having the same issues please? Unfortunately the router doesn't seem connected at the moment so I'm unable to test the line.
 Chris Parr
 Plusnet Staff
rmacaulay1979
Hi, sorry but we had an electrical fault this morning and so unplugged every appliance including the router. Will turn back on this evening and get back to you.
rmacaulay1979
Hi that's my modem back on. Upload is the same. Sometimes giving zero upload for half of the test (several seconds) then jumps up a bit. I think this is what is causing the problem with streaming. Web browsing etc is slow once something is clicked on. Getting 12 Mbps download and about 1.2 upload.
Fixes: 225
Moderator's note:
Duplicate post removed.
Forum Moderator and Customer
Fixes: 440
Our tests aren't showing any problems. Your upstream speed of 1.2mbps looks right on target for your connection.
However, since you've advised it's fluctuating, are you using a wired or wireless connection?
rmacaulay1979
Using wireless but testing near the router with strong signal.
