Very slow upload speeds
- Re: Very slow upload speeds
27-03-2020 10:05 AM
Hello - hope everyone is keeping well.
As with the vast majority of the population I'm working from home and woefully low upload speeds (below 0.4 Mbps) are becoming a real issue when working on files with colleagues etc.
I've tried the chat and phoneline and understandably its busy but is there anything I can do to sort this myself?
cheers all
Mark
27-03-2020 10:16 AM
@MarkMWR1 Welcome to the forum
I assume as you have posted on this board that you are on an ADSL connection? Are you using a Plusnet Hub Zero router?
The upload limit for ADSL is only about 1Mbps on a good connection. If you put your phone number in here what range of speed do you get? https://my.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
Also note that you can only use your bandwidth once so if you are trying to download at the same time this will screw up your upload speed.
27-03-2020 11:02 AM
Ah, ok then it might be that I need a new provider if working from home continues for the foreseeable. Thanks!
27-03-2020 11:13 AM
@MarkMWR1 Changing ISPs is rather pointless - the limits @Baldrick1 point out are infrastructure related, not ISP related. The only way to improve them is to move from ADSL to Fibre -if possible, and given the current situation, that could be a long drawn-out timescale.
27-03-2020 11:41 AM
Very good point John, longer term think fibre will have to be way forward but I best not add to the workload of engineers right now!
