Very slow upload speed - or am I expecting too much?
cpcjones
I have no idea whether my upload speed (around 30kbytes/sec transferring a dropbox file) is acceptable or rubbish, seems pretty slow to me! Here is the data from my router, speedtest etc:
Router data:
Bandwidth (Up/Down) [kbps/kbps]: 443 / 10,647
Data Transferred (Sent/Received) [MB/MB]: 3.35 / 26.11
Output Power (Up/Down) [dBm]: 12.4 / 0.0
Line Attenuation (Up/Down) [dB]: 17.0 / 34.0
SN Margin (Up/Down) [dB]: 29.9 / 6.0
BT speedtest
1. Best Effort Test:  -provides background information.
Download  Speed
6.28 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.28 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 9.39 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.08 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.08Mbps
Upstream Rate IP profile on your line is - 0.45 Mbps
Current line speed:
7.9 Mb
Fixes: 10
Re: Very slow upload speed - or am I expecting too much?
Your upload is currently capped at 448kbps. You need to ask for it to be uncapped.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
burrowsp
Hi cpcjones,
I agree with jelv that your upload speed is capped, as I am in an identical situation, having move to Plusnet Broadband Unlimited last Monday.
I have raised a ticket to get the upload cap removed (76502007). However, that was 80+ hours ago and the ticket has not been responded to as yet. You may get a better response time to any ticket you raise after the weekend.
cpcjones
Thank you both, I will raise a ticket with plusnet tomorrow morning!
Fixes: 10
Raise the ticket straight away - there's no point in delaying.
burrowsp
96+ hours now and my ticket (76502007) is still awaiting being picked up.
@cpcjones, your order's been placed and should complete tomorrow.
@burrowsp, I believe Adam's picked up one of your other posts on this issue and addressed it already.
burrowsp
Many thanks Matt. Adam has indeed picked this up and it's expected to be implemented tomorrow.
