Very slow today...
- Re: Very slow today...
Very slow today...
04-02-2011 12:16 PM
I've also noticed that my usage is way up according to PlusNet - much higher than it should be (the only other times we have reached anything like our limit, we have had big downloads, so we knew to expect it). Any ideas? Cheers
04-02-2011 1:00 PM
I'm going to do another check of the router and all connections. If there's nothing wrong there, then I'll have to raise a ticket.
04-02-2011 1:14 PM
04-02-2011 2:44 PM
04-02-2011 2:49 PM
We've had some calls about this this afternoon.
Our Networks Team are currently investigating.
I'm sorry for the hassle that it's causing you.
04-02-2011 3:04 PM
Our network team are investigating the cause of these issues, I've asked one of my team to do some additional dial-testing from here so we can try to replicate the issue.
04-02-2011 5:48 PM
04-02-2011 5:55 PM
This means that any screw up in the ellacoya profiling system is unlikely to affect them.
That is my opinion which, of course, may not be correct but does fit the facts as I see them.
04-02-2011 5:56 PM
Tried to use Iplayer but useless even online radio listening stutters all the time.
Adam
04-02-2011 6:16 PM
I managed to do a basic speedtest. My connection speed seems to be between 200-300kbps, with the upload speed being greater!
I checked all the usual stuff, just to make sure it's not a problem on my end, such as the line signal (which is clear), router, the microfilter etc... I even tried it on another PC. All with the same results I'll keep checking the speeds I'm getting every now and again. Like I said, I hope it gets sorted out.
04-02-2011 7:01 PM
Downstream: 344 kbps (43kB/s) Upstream: 377 kbps (47.1kB/s)
I'm sync'd at 7616kbps and my profile is 6.5mb. I was about to start troubleshooting when I saw the service status message. I hope it is a general problem and not a problem specific to my set-up. I've just recently been able to get a line fault fixed and am not looking forward to another several days of experimenting with alternative equipment and set-ups.
Jim
04-02-2011 7:06 PM
Definitely seems to be a traffic prioritisation issue. Online gaming seems completely unaffected by the issue, but web browsing is painfully slow. AIUI gaming is Titanium, but browsing is only Gold.
04-02-2011 7:33 PM
Ex-Broadband Service Manager
04-02-2011 7:37 PM
Use the router web interface to disconnect then reconnect from Plusnet
04-02-2011 7:47 PM
A speed test confirms that Downstream speed is now back to around 5900kbps
Looks like it's sorted. Thanks.
Jim
