Very slow speeds
- Very slow speeds
Very slow speeds
24-02-2012 4:29 PM
Re: Very slow speeds
24-02-2012 10:07 PM
27-02-2012 11:57 AM
If there is anything we can help with please let us know
05-03-2012 9:34 AM
I am currently synced at 5792kbps so please could my profile be put back up to where it should be as I am experiencing speeds that are far too low.
05-03-2012 9:41 AM
Is it the IP profile as reported by the BT Speedtest or the Plusnet mirror of it from https://portal.plus.net/my.html?action=data_transfer_speed
Also, in your previous thread you stated
DownStream Connection Speed 7648 kbps
UpStream Connection Speed 448 kbps
This is a major drop to the speed you are now seeing so something is still adrift
05-03-2012 9:42 AM
05-03-2012 9:46 AM
05-03-2012 9:55 AM
In any case, as I assume that you are on 20CN, it can take anything up to 3 days for it to update.
I assume that you have done the BT Speedtest - if you could post the result it will help the staff
05-03-2012 10:03 AM
05-03-2012 10:11 AM
05-03-2012 10:21 AM
Quote from: Oldjim This may give the same information - IP profile that is - http://windows.mouselike.org/be/index.asp?DoAction=BrasChecker
Thanks for that link. Really could do with a tester that does not need Java!
The Service ID is: [hidden]
This is a 20CN line.
Looks like BT refused to test, possibly because a speed test or BRAS check has been run recently which prevents this tool from working. Try again in a few hours.
