Very slow speeds and can't connect to work VPN (dns failure)
- Re: Very slow speeds and can't connect to work VPN...
02-10-2015 9:59 AM
When I try to connect to the VPN (nottshc.nhs.uk) I just get a DNS resolution failure.
My work has provided me with an alternative DNS www.access.nottshc.nhs.uk this does not work either.
I ran a tracert on this and found that there was timeouts/huge latency when traversing the virgin media network causing it to fail to connect/remain connected.
Is there anything you can do about this?
In addition to this it took 10 minutes to load these forums so I suspec there is a line or network fault as well.
I am not technical so could you please test my line and/or look at the dns issues I am having?
I may have to consider changing bb provider if not as I regularly need to work from home sadly.
Many thanks!
Re: Very slow speeds and can't connect to work VPN (dns failure)
02-10-2015 1:09 PM
A warm welcome to the forums.
This rather looks like an issue with your employer's IT services. nottshc.nhs.uk does not appear to have any DNS routing information what so ever... neither PlusNet's nor Google's DNS has an IP address for that URL
#Microsoft Windows [Version 6.1.7601]
#02/10/15-12:57:57.43
C:\Users\Kevin>nslookup
Default Server: dsldevice.lan
Address: 192.168.1.254
> set type=any
> nottshc.nhs.uk
Non-authoritative answer:
nottshc.nhs.uk
primary name server = external.nhs.uk
responsible mail addr = hostmaster.nhs.uk
serial = 2015081401
refresh = 86400 (1 day)
retry = 3600 (1 hour)
expire = 604800 (7 days)
default TTL = 600 (10 mins)
nottshc.nhs.uk nameserver = nsb.nhs.uk
nottshc.nhs.uk nameserver = nsa.nhs.uk
nottshc.nhs.uk nameserver = ns.nhs.uk
nottshc.nhs.uk MX preference = 50, mail exchanger = mail.nhs.uk
nottshc.nhs.uk MX preference = 50, mail exchanger = mail2.nhs.uk
> server 8.8.8.8
Default Server: google-public-dns-a.google.com
Address: 8.8.8.8
> nottshc.nhs.uk
Address: 8.8.8.8
nottshc.nhs.uk
serial = 2015081401
#02/10/15-13:00:22.95
C:\Users\Kevin>tracert nottshc.nhs.uk
Unable to resolve target system name nottshc.nhs.uk.
There appears to be internet routing issues somewhere in Virgin Media's network to www.access.nottshc.nhs.uk
#02/10/15-13:00:38.06
C:\Users\Kevin>tracert www.access.nottshc.nhs.uk
Tracing route to www.access.nottshc.nhs.uk [86.28.18.68]
over a maximum of 30 hops:
1 242 ms 6 ms 1 ms dsldevice.lan [192.168.1.254]
2 38 ms 33 ms 35 ms lo0-central10.ptn-ag01.plus.net [195.166.128.190]
3 33 ms 33 ms 32 ms link-b-central10.ptn-gw02.plus.net [212.159.2.130]
4 32 ms 32 ms 33 ms xe-5-2-0.ptw-cr02.plus.net [212.159.0.106]
5 33 ms 34 ms 36 ms linx-gw2.router.ntli.net [195.66.236.22]
6 35 ms 35 ms 38 ms brnt-bb-1a-ae14-0.network.virginmedia.net [212.250.14.201]
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 38 ms 37 ms 39 ms brhm-core-2b-ae2-0.network.virginmedia.net [62.254.84.129]
11 45 ms 37 ms 38 ms brhm-lam-2-tenge21.network.virginmedia.net [213.106.231.250]
12 62 ms 45 ms 39 ms 41.63-255-62.static.virginmediabusiness.co.uk [62.255.63.41]
13 40 ms 40 ms 40 ms 68-18-28-86.static.virginm.net [86.28.18.68]
Trace complete.
#02/10/15-13:03:26.24
C:\Users\Kevin>pathping www.access.nottshc.nhs.uk
0 ADVENT.lan [192.168.1.71]
1 dsldevice.lan [192.168.1.254]
2 lo0-central10.ptn-ag01.plus.net [195.166.128.190]
3 link-b-central10.ptn-gw02.plus.net [212.159.2.130]
4 xe-5-2-0.ptw-cr02.plus.net [212.159.0.106]
5 linx-gw2.router.ntli.net [195.66.236.22]
6 brnt-bb-1a-ae14-0.network.virginmedia.net [212.250.14.201]
7 * * *
Computing statistics for 150 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 2ms 0/ 100 = 0% 0/ 100 = 0% dsldevice.lan [192.168.1.254]
1/ 100 = 1% |
2 63ms 1/ 100 = 1% 0/ 100 = 0% lo0-central10.ptn-ag01.plus.net [195.166.128.190]
0/ 100 = 0% |
3 54ms 1/ 100 = 1% 0/ 100 = 0% link-b-central10.ptn-gw02.plus.net [212.159.2.130]
0/ 100 = 0% |
4 56ms 1/ 100 = 1% 0/ 100 = 0% xe-5-2-0.ptw-cr02.plus.net [212.159.0.106]
0/ 100 = 0% |
5 50ms 1/ 100 = 1% 0/ 100 = 0% linx-gw2.router.ntli.net [195.66.236.22]
99/ 100 = 99% |
6 --- 100/ 100 =100% 0/ 100 = 0% brnt-bb-1a-ae14-0.network.virginmedia.net [212.250.14.201]
Trace complete.
I hope this helps you progress the problem with your employer's IT support.
You can point you IT staff to these diagnostics using this link - right click the link and choose 'copy shortcut' then paste into an email to your IT support..
02-10-2015 9:32 PM
02-10-2015 9:45 PM
As ever its always good to have another set of eyes on a problem... "there appears to be a routing problem" was intended to mean "there might be"
As you state it is very slow which might give rise to the browser timing out the connection. The https:// connection is more than passing interest, it means there is noting responding on port 80, the usual 'target' for a web site.
Interestingly when I tried to connect to that service (using https) I get the following "dangerous site" warning...
There is a problem with this website’s security certificate.
The security certificate presented by this website was not issued by a trusted certificate authority.
Security certificate problems may indicate an attempt to trick you or intercept any data you send to the server.
We recommend that you close this webpage and do not continue to this website.
02-10-2015 10:17 PM
Perhaps nottshc.nhs.uk only resolves once connected to the VPN. I don't know the specific instructions or software provided.
These forums shouldn't take 10 minutes to load. They are so old fashioned and simple I find they load faster than a big modern website. It may have been a one off, or if other websites are slow to load, suggests a general connection issue.
