Very slow for over 2 hours
Dudgers
Im getting between 1-2 mbps..
Can you look into this please.
3 REPLIES 3
EmilyD
Fixes: 117
Re: Very slow for over 2 hours
Hi @Dudgers,
I'm sorry that you've been experiencing poor speeds and for any inconvenience that this has caused you. I've tested your line but the test isn't picking up any problems at the moment and indicates that your line is currently syncing at 24mbps:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 24.0 Mbps
Upstream Speed 2.4 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 1427.9
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ;00:00to23:45
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream 3dB, Retransmission High - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2019-08-12T12:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 25.4 Mbps 26.3 Mbps 26.0 Mbps
Up Stream Line Rate 2.3 Mbps 3.0 Mbps 2.8 Mbps
Up Time 690.0 Sec 900.0 Sec 899.5 Sec
Retrains 0.0 2.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-08-25T10:59:07Z 2019-08-25T11:14:07Z
Ingress Code Violation 7 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
If the speed is still poor on your side, please can you confirm whether this is solely affecting wireless connections or if wired connections are affected too?
 Emily D
Dudgers
Hi Emily..
the speed picked up after a few hours of posting this...
Is there a higher speed available with plusnet in my area i could upgrade to?
SammyM
Fixes: 87
Hello @Dudgers,
We are happy to hear that your speed has now increased. I have checked the services available in your area and you are on the fastest speed available for your line I am afraid.
You can keep an eye on this here, should a faster speed become available. Please get back to us if you have any further queries.
 Sammy M - Sheffield Team
