Very slow connection in first week
- Very slow connection in first week
17-10-2008 9:21 PM
Today 20:40 106 kbps (13.3kB/s) 47 kbps (5.88kB/s) Share
Today 19:24 103 kbps (12.9kB/s) 53 kbps (6.63kB/s) Share
Yesterday 17:53 65 kbps (8.13kB/s) 48 kbps (6kB/s) Share
Wednesday 18:54 66 kbps (8.25kB/s) 54 kbps (6.75kB/s) Share
Tuesday 18:59 106 kbps (13.3kB/s) 52 kbps (6.5kB/s) Share
Monday 23:20 106 kbps (13.3kB/s) 35 kbps (4.38kB/s) Share
Monday 22:34 106 kbps (13.3kB/s) 37 kbps (4.63kB/s)
Re: Very slow connection in first week
17-10-2008 9:34 PM
Can you give us the stats from your router
Synch speed
Noise Margin
Attenuation
17-10-2008 10:59 PM
18-10-2008 11:19 AM
Link Information
ive got these details from the thompson site,
Uptime: 0 days, 15:57:09
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 64 / 128
its the first time ive had broadband let alone wireless, im not sure how to reset 'sync speed' is this the 54Mbps?. ive turned the modem off and on each day to reset the connection and the bt web sits says no problems with my line, my line should be capable of about 2.5m ive got option 3 30 mb so havnt gone ova my allowance
18-10-2008 11:42 AM
18-10-2008 12:48 PM
Please ensure you are connected to your test socket and if you are still showing the same speeds then raise this using our Broadband Faults Checker at the following link.
http://faults.plus.net/
If you are not sure what I mean by the test socket, there are some guidelines on the following page which should make this clear.
http://www.plus.net/support/broadband/troubleshooting/test_socket.shtml
18-10-2008 3:47 PM
Link Information
Uptime: 0 days, 0:10:04
Output Power (Up/Down) [dBm]: 9.0 / 9.5
Line Attenuation (Up/Down) [dB]: 28.0 / 46.0
SN Margin (Up/Down) [dB]: 31.0 / 30.5
Vendor ID (Local/Remote): TMMB / P
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
18-10-2008 4:03 PM
It is obvious that there is a BT problem but I am very surprised about the high upstream attenuation.
Is that with the router plugged into the test socket
18-10-2008 4:05 PM
Exchange contention status: Red
The local telephone exchange, from where your broadband service is provided is currently experiencing very high levels of contention, with many broadband users. As a result of this, you may experience slower connection speeds during busy periods.
Please note that BT regularly upgrade the capacity of their telephone exchanges. We will monitor the BTs engineering schedules, please check back on a weekly basis for further updates.
this s the resxult of the fault checker, but my broadband is slow at all times and very slow
18-10-2008 4:06 PM
18-10-2008 4:11 PM
http://www.plus.net/support/broadband/bbfaults/howto.shtml
Quote Speed Faults
Your exchange status will be checked to see if there are any contention problems, if anything is found then you won't be allowed to continue, so you'll need to call our Support Team or raise a ticket to talk about this.
I suggest raising another ticket or phoning or wait for a member of the comms team to pick it up here.
18-10-2008 5:26 PM
There is plenty of headroom on the downstream SNR ( 30.5 ) for it to sync faster but for some reason its stuck at 128.
Seen them stuck at 512 before but 128, thats really odd!!!
18-10-2008 5:28 PM
18-10-2008 5:47 PM
http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=btsupplier&Number=3451287&page=&view=&sb=&o=
http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=btsupplier&Number=3413721&page=&view=&sb=&o=
20-10-2008 10:28 AM
Phil Richardson has already identified a few of these on the forums - I wonder if I can wake up one of the comms chaps/chapesses and get Phil to take a look.
B.
