Very slow bb speeds the last 2 nights
- Very slow bb speeds the last 2 nights
31-10-2011 8:44 PM
I've been getting very slow speeds the last 2 nights
Done a speed check and I'm geting .22 download and .03 upload. Not happ...... normally I get 6.5 dl and .37 ul.
I tried calling the support line and got fed up after being on hold for 20 mins. Is there are general issue atm ?
Message 1 of 3
(6,385 Views)
2 REPLIES 2
Re: Very slow bb speeds the last 2 nights
31-10-2011 11:53 PM
31 views and no replies
can anyone help ?
can anyone help ?
Message 2 of 3
(317 Views)
01-11-2011 2:59 AM
Hello gooner77. Currently going through the same situation. Can you remember when it went slow. Mine went bad at 12 midnight on my billing date. I usually get a 23Mb download and a 1.5Mb upload. It's been like this for six days now and I've still had no explanation of why it's like this and I'm really starting to get frustrated.
Plusnet have also just tested my line for faults and it had none. They also reported a download speed of 26 Mb. Straight after I got these results, I done a speed test and I'm still getting the same 0.2 Mb download
Do your speed results look similar to this
I usually have a much lower ping aswell.
Have you tried a BT speedtest ? I tried it on that one and it gave results of what my speed should be anyway.
So if you haven't already, I'd suggest the BT speedtest and if your result's are coming back normal. Then it's foul play on Plusnet's end I think.
Well i've blabbered on for a bit. Hope this helps
Message 3 of 3
(317 Views)
