Very slow ADSL
oldsch00l
Very slow ADSL
Over the last 24-48 hrs I have seen a drastic drop in my ADSL speed - typically getting ~4-5 mbps prior to this.
Testing with wired connection, directly to router, no other active network devices.
Router Stats:
Down Rate=4256Kbps, Up Rate=448Kbps; SNR Margin Down=12.2dB, Up=24.0dB
BT Speedtest
Consistently giving between 0.1 to 0.5 mbps d/l and 0.3 to 0.4 mbps u/l
Further Diagnostics:
Download speed achieved during the test was - 0.2 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
Additional Information:
Your DSL Connection Rate :4.26 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.14 Mbps
PlusNet site showing Current Line Speed: 21Mbps - which is clearly an error as I've never had anything approaching that.
I have tried logging a ticket with PlusNet Tech Support, but currently 23 people waiting on Chat and 55 minute wait on phone...
Any help/escalation much appreciated!
Thanks,
Ross
1 REPLY
Fixes: 167
Re: Very slow ADSL
Hi Ross,
I'd advise getting this reported to us as a fault at https://faults.plus.net
 Chris Parr
 Plusnet Staff
