Very poor connection
- Re: Very poor connection
27-09-2016 9:16 PM
My router is plugged into the master socket and have checked all lead and phone line working.
28-09-2016 12:30 AM
Hey,
It might be worth changing your Wireless Channel, we've got a Support Guide/Video which talks you through how you can do that: https://www.plus.net/help/broadband/router-user-guides/ under the "How do I change my wi-fi settings?"
28-09-2016 8:49 AM
28-09-2016 12:39 PM
28-09-2016 7:52 PM
Which router do you have?
It may be worth downloading a WiFi Analyser such as 'inSSIDer' to see if your signal is being blocked out from other nearby routers.
Also if its a Hub 1 you have separating the 2.4 and 5Ghz services can help. Finally, are you seeing stronger signals from other WiFi services on your laptop, could your laptop have a problem?
29-09-2016 8:29 AM
There is no issue with the laptop as it is 2 weeks old and have connected it to different wi-fi networks and received full signal with no problems
01-10-2016 9:15 AM
try this thread https://community.plus.net/t5/Broadband/Internet-page-request-timed-out/td-p/1372233 people seem to be having issues with windows 10 at the moment! Personally I stick to the last known working windows...xp haha
