Very poor browsing today.
- Very poor browsing today.
01-03-2013 9:46 AM
Re: Very poor browsing today.
01-03-2013 9:47 AM
01-03-2013 9:48 AM
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
01-03-2013 9:49 AM
01-03-2013 9:50 AM
01-03-2013 9:52 AM
Quote from: Kelly We are in the process of adding 2 more bits of kit (one is going live tomorrow) which should put enough kit in the network to prevent a reoccurrence of the issue.
01-03-2013 10:30 AM
I've checked your line and everything seems OK, I can see your connection has disconnected & reconnected, any improvement?
01-03-2013 11:11 AM
01-03-2013 11:37 AM
01-03-2013 11:40 AM
01-03-2013 11:41 AM
Pinging www.bbc.net.uk [212.58.246.91] with 32 bytes of data:
Reply from 212.58.246.91: bytes=32 time=11ms TTL=56
Reply from 212.58.246.91: bytes=32 time=10ms TTL=56
$ wget www.bbc.co.uk
--2013-03-01 11:27:35-- http://www.bbc.co.uk/
Resolving www.bbc.co.uk (www.bbc.co.uk)... 212.58.244.66
Connecting to www.bbc.co.uk (www.bbc.co.uk)|212.58.244.66|:80... failed: Connection timed out.
Is there some sort of transparent proxy stuff going on ?
Something is mucking about with web connections, I have a couple of working pages that autorefresh, any new connections fail
Everything else appears to have dropped off the interwebs
Oh and as an aside, when there is a routing problem, having all the plusnet pages sprinkled with google analytics links is really frustrating.
01-03-2013 11:42 AM
Quote from: rookey How do you do that test please can it be done on the mac?
That was done with software called Pingplotter. Not sure about doing it on a Mac; someone will be able to help though I'm sure.
01-03-2013 11:52 AM
01-03-2013 11:52 AM
01-03-2013 12:06 PM
Quote from: chrispurvey Could you run a speed test at http://speedtest.btwholesale.com and run further diagnostics once its completed?
Nothing untowards here...
