Very poor browsing today.
nozzer
Connection problems from the word go! My router's fine and not losing sync, but browsing is very bad, almost as though there's a DNS problem. Anyone else experiencing this?
19 REPLIES 19
rookey
Re: Very poor browsing today.
I am having this problem too as I mention it in my thread
Fixes: 1,483
things are ok here.
AndyH
Which gateway are you connected to? (you can find out here - http://usertools.plus.net/@gateway)
nozzer
pcl-ag05. Last time I had anything like this it turned out to be a gateway router failing.
AndyH
Kelly said last night they were adding some new kit today - not sure if it's linked to that
Quote from: Kelly
We are in the process of adding 2 more bits of kit (one is going live tomorrow) which should put enough kit in the network to prevent a reoccurrence of the issue.
chrispurvey
Hi nozzer,
I've checked your line and everything seems OK, I can see your connection has disconnected & reconnected, any improvement?
nozzer
Yes, changed gateways but no different.
nozzer
See attached pic of a pingplot...  this is what seems to be happening, short bursts of very high latency. Seems to have calmed down a bit at the moment bit during peak times it's bad.
rookey
How do you do that test please can it be done on the mac?
CrashBangWallop
Also having problems getting around the net, at first I thought it was DNS but its not
Pinging www.bbc.net.uk [212.58.246.91] with 32 bytes of data:
Reply from 212.58.246.91: bytes=32 time=11ms TTL=56
Reply from 212.58.246.91: bytes=32 time=10ms TTL=56
$ wget www.bbc.co.uk
--2013-03-01 11:27:35--  http://www.bbc.co.uk/
Resolving www.bbc.co.uk (www.bbc.co.uk)... 212.58.244.66
Connecting to www.bbc.co.uk (www.bbc.co.uk)|212.58.244.66|:80... failed: Connection timed out.
Is there some sort of transparent proxy stuff going on ?
Something is mucking about with web connections, I have a couple of working pages that autorefresh, any new connections fail
Everything else appears to have dropped off the interwebs
Oh and as an aside, when there is a routing problem, having all the plusnet pages sprinkled with google analytics links is really frustrating.
nozzer
Quote from: rookey
That was done with software called Pingplotter. Not sure about doing it on a Mac; someone will be able to help though I'm sure.
chrispurvey
Could you run a speed test at http://speedtest.btwholesale.com and run further diagnostics once its completed?
glloyd
I thought it was just  me but some pages seem to take ages to load. Looks like a  routing problem somewhere.
nozzer
Quote from: chrispurvey
Nothing untowards here...
