Very low speed ip profile
msu_global
I have been with plusnet for more that 3 years but my internet speed has always been unstable tbh.
I wrote to Plusnet through their email and twitter accounts as I am UNABLE to communicate over phone due to an ongoing health condition (however someone from Plusnet was trying to reach me by phone after I used the HELP text service).
SINCE several days (7-10 days), the download speed has been continuously around 9MB to 24MB although I am on the Unlimited Fibre Extra (with an estimated download speed of 66MB).
I am an experienced network engineer myself so I did all the required tests (including the ones recommended by Plusnet) with the Plusnet Hub directly connected to the master socket.
Please URGENTLY check this from your end in order to rectify this situation.
If you need to communicate with me, please only use texts/emails.
Downstream: 16.49 Mbps
Upstream: 5.127 Mbps
66Mb
8 REPLIES 8
Fixes: 382
Re: Very low speed ip profile
@msu_global Plusnet staff response on here can be a little slow, so I suggest you try the following:
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
msu_global
Thanks John for your kind support!
As I already explained, I tried all the recommended and possible tests. Unfortunately, I don't have a phone in order to check if there is a noise in the line.
I still have a slow connection and hope someone from Plusnet could see my messages and help solving this issue.
Fixes: 382
@msu_global A cheap wired phone handset is a great help in diagnosing problems on an ADSL/FTTC connection. However, if you don't have one, bearing in mind staff response on here is a little slow:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
msu_global
Many thanks again for your time dear John.
I got a reply from Plusnet on twitter, and they confirmed "there is a fault on the phone line which may be impacting on the speed of your connection".
TheMightyAJ
Fixes: 126
Hi @msu_global,
Thanks for bringing this to our attention and I'm very sorry to hear that you've been experiencing these issues. I've picked up the twitter conversation now and have sent a further message to you.
 Alex H
msu_global
Hi @TheMightyAJ
Many thanks for your time.
I am thinking to upgrade to a Full Fibre contract. I think this should be an alternative solution (possibly a quicker and more effective one) as an upgrade from normal broadband to Full Fibre will mean a completely new ip profile + avoiding the faulty line causing issues.
Can you please correct me if I am wrong?
Fixes: 382
@msu_global If you can get Full fibre, this will eliminate a lot of issues, and should guarantee an almost trouble-free service.
Just to note, you will lose your voice service.
TheMightyAJ
Fixes: 126
Thanks for getting back to us @msu_global. I can see you sent a similar message over on Twitter, so I've responded there. If you have any further questions then please don't hesitate to get back in touch and we'll be happy to help Smiley
 Alex H
