Very low download speeds.
- Very low download speeds.
15-06-2009 10:31 PM
Here's my most recent speed test.
I'm on the Plusnet Pro package and although for gaming Plusnet been an absolute godsend, these speeds are much much lower than I was receiving with my previous ISP in regards to browsing/downloads.
My router is successfully syncing at 448 / 8,128
Re: Very low download speeds.
15-06-2009 10:33 PM
did you change routers when moving to plusnet?
also can you post your line stats
http://www.kitz.co.uk/adsl/frogstats.php
and your bt an PN profile http://speedtester.bt.com/ and https://portal.plus.net/my.html?action=data_transfer_speed
15-06-2009 10:52 PM
My MTU is at 1492 and my RWIN is 255552, these are the numbers I was using with my previous provider, Tiscali, and have remained unchanged.
I should note that between 00:00 and 08:00 when I use BitTorrent in order to take advantage of the unmetered access, download speed generally seems fine and is certainly much much higher than the numbers I'm getting during the evening.
Uptime: 1 day, 21:00:40
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 17.5 / 27.0
SN Margin (Up/Down) [dB]: 27.0 / 9.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 2 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 103 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 367
HEC Errors (Up/Down): 0 / 239
Telephone number:
01463xxxxxx
Phone exchange:
INVERNESS MACDHUI
Estimated line speed:
8 Mbps - Checked on 2009-05-12 22:03:11
Current line speed:
7150
Having trouble with getting the BT Speedtester to work at the moment.
15-06-2009 10:58 PM
did you not know about the traffic mangment on p2p. your web browsing and speedtest results should be fine tho
edit
forget that your on pro
what are your IP profiles?
15-06-2009 11:18 PM
I should also add that although my download speeds seem abnormally slow, my overall throughput seems to be phenomenal, I've been in 100+ player Wintergrasp battles in World of Warcraft at various times of day, with a latency rarely exceeding 90ms. So no issues there
It's just a bit of an annoyance when I often have to wait on overly long amount of time between web pages while surfing.
15-06-2009 11:20 PM
didnt see your edit.
yeah the BT one gets busy messages at peak times
15-06-2009 11:30 PM
15-06-2009 11:39 PM
15-06-2009 11:56 PM
16-06-2009 12:22 AM
16-06-2009 12:46 AM
16-06-2009 9:10 AM
That capture shows your web traffic in Gold, which is normal.
I'm concerned that your rWin seems rather high. Can you try using a figure of 111200 with an MTU of 1430 on both your computer and router?
16-06-2009 10:05 AM
Just out of curiosity, how do I go about changing the RWIN and MTU of the Thomson TG585 that Plusnet supplied?
16-06-2009 10:36 AM
I'm not entirely sure where you change the MTU on the router itself but I'm sure someone will be along shortly to let you know
16-06-2009 10:46 AM
http://forum.zensupport.co.uk/thread/18173.aspx tells you how to do it
