Very low broadband speed over the past 7 days
armanes
I currently have an appalling 0.4mb speed . Over the past 7 days the service has been either disconnected (perhaps due to planned maintenance) or very low. My username is armanes
jonc1
Re: Very low broadband speed over the past 7 days
Hello armanes,
I totally agree with your comment, except I have had this exact problem for 3 - 4 weeks, particularly evenings, and have filled in numerous surveys highlighting my concerns - but no response or improvement. It can only be called ABYSMAL- you pay your money but receive a service not worth a penny. My username is jonc1
geek26
I would advise raising a broadband fault at faults.plus.net
James
jonc1
Thanks James, but I don't expect much action.
jonc1
Plusnet Staff
Plusnet Staff
Fixes: 159
@armanes
I can see this was reported as a phone fault and we've been advised that an engineer has resolved a fault in the network external to your premises. As that's now showing as resolved, I've reset your broadband line and you should be getting back to your normal speeds, if it's still low try a single disconnect/reconnect of the router.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 159
@jonc1
Looking at your line, with the exception of Thursday it's been extremely stable:
Testing your line is showing the sync rate is exactly where we'd expect this to be based on your estimates:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 22.1 39.5
SNR Margin: 6.0 6.6
Errored Seconds: 0 3
HEC Errors: 0
Cell Count: 92202 196588
Speed: 1207 7027
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 6 -- 4 to 8 Available -- --
I can see you started raising a fault, but not all the questions were answered. If you're getting evening slowdowns I'd advise reporting a fault and completing all the questions at https://faults.plus.net
 Chris Parr
 Plusnet Staff
