Very bad upload speeds and Xbox gaming terrible
- Very bad upload speeds and Xbox gaming terrible
08-08-2015 3:01 AM
I have the plusnet technicolor TG582N and I'm
Getting very bad upload speeds.
I currently have version 10.2.2.b
When I use wi fi or wired I get an upload speed of 0.69
My ping is also 52 which is not great.
Any way I can fix it? Is there a new firmware update out and if so how can I find it?
Thank you.
Re: Very bad upload speeds and Xbox gaming terrible
10-08-2015 9:47 AM
speed fault "sticky" at the top of the forum, do the tests and post the results.
10-08-2015 10:35 PM
A warm welcome to the forums.
That upload speed does not seem too abnormal, however as already suggested a full set of information is neede for us to advise you. See the speed issues link below.
Check the line for noise, dial 17070 option 2 using a corde phone plugged into the master socket. Is the router plugged into the master socket? Are there any extensions, if yes how are they wired?
When you've obtained the requested information, we'll be able to take a view on how to proceed.
11-08-2015 9:57 AM
As Townman says your upload speed isn't bad at all for an ADSL2+ connection, your upload is synced at 1167 so you may be able to get a very small increase in the throughput but it's unlikely to be a significant improvement.
Where are you seeing those ping results from?
11-08-2015 10:25 AM
Broadband suddenly turned off :( help
07-10-2015 12:28 AM
Re: Broadband suddenly turned off :( help
07-10-2015 1:05 PM
i.e. post the stats from your router.
07-10-2015 2:00 PM
Threads merged to keep continuity.
