Very Slow Upload Speed
- Very Slow Upload Speed
10-05-2010 8:14 AM
Re: Very Slow Upload Speed
10-05-2010 9:38 AM
That speed test is wrong.
The theoretical maximum speed on an 8Mb line is 7.15Mb, due to overheads and BT line profiles.
Further to that, you specific profile has been set at 6.5Mb for the last few days.
What are the upload stats in your router control panel?
10-05-2010 11:14 AM
10-05-2010 11:25 AM
10-05-2010 11:29 AM
So Router shows -- Bandwidth (Up/Down) [kbps/kbps]: 64 / 7,808
10-05-2010 11:32 AM
Is there any noise on the line - dial 17070 option 2 Quiet Line Test
Have you another router you can try
10-05-2010 1:14 PM
Not sure if this problem was there previously as hadn't had a reason to check it until I moved PC locations.
Are you saying it is just my upload speed is a major problem or both?
10-05-2010 1:16 PM
EDIT
Just spotted something.
You said that you ran a new line from the filtered master faceplate for voice and broadband - if this was a single wire from one of the outputs on the master faceplate that will have messed things up very badly
10-05-2010 1:29 PM
Router Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,648
This seems to be correct now but don't understand how colour coding on ADSL socket is wrong and that it half works if connected incorrectly..?
10-05-2010 3:33 PM
If so looks like I screwed up when I changed PC location..
Thanks to all for your help, it did point me in the right direction regarding line connections.
10-05-2010 4:07 PM
Glad we could help
