Very Slow Upload Speed on my Broadband
- Very Slow Upload Speed on my Broadband
04-04-2012 8:16 PM
It has been apparent for many weeks that the upload speed is at a ridiculous speed.
For example: I had a 5.4gb video uploading to youtube, I left the computer connected for 14hrs and only 36% of the video was uploaded.
From all my upload speed tests it varies from 36kbps to 45kbps.
This is remarkably slow.
I have checked the router and located the line rate - Upstream / Downstream.
The results are as follows:
Line Rate - Upstream (Kbps): 448
Line Rate - Downstream (Kbps): 13087
*Surely this is below the standard*
I have never had such a slow upload speed, and I can't stream any game play either, due to the very low rate upload speed.
Hope you can help.
Thank you.
EDIT:
Update;
broadbandspeedchecker.co.uk
Speeds:
Download Speed:
10.55 Mb/s
Upload Speed:
0.365 Mb/s
Re: Very Slow Upload Speed on my Broadband
04-04-2012 8:48 PM
Download Speed = 9.79Mbps
IP Profile for your line is - 11.54Mbps
Upload Speed = 0Kbps
Max Achievable Speed = 448kbps
(Something needs changing) looks like we're restricted a lot.
04-04-2012 9:49 PM
The 448kbps upload is the standard upload speed, but as you appear to be on ADSL2+ you can ask to have it "uncapped" for free, to about 1Mbps.
04-04-2012 10:19 PM
If you have the upload uncapped you'll probably double the upload speed and maybe a little bit more.
The only way you will get upload faster than that is by going to fibre if it is available to you.
04-04-2012 10:37 PM
Is it easy to get sorted?
(Fibre Optic) was installed in my estate a long time ago, but not actually installed for use (not connected).
Virgin Media have been contacting us for like 2 years and the same result is (we can't have it). + I dislike VM (my Son used them at University) poor service from them.
Anyway, hopefully something can be done.
I can't do anything with that speed.
04-04-2012 10:38 PM
04-04-2012 11:05 PM
EMWSBCH (Wisbech)
04-04-2012 11:32 PM
05-04-2012 12:45 AM
My son had 50MB Fibre Optic (nothing but problems with wireless) connected via the ethernet up two floors.
Hope the UL Speed can at least be near 1mb. 🙂 or treble what it is at the moment.
05-04-2012 4:53 PM
Please can someone official from Plusnet - help me out.
Thank you.
05-04-2012 5:06 PM
05-04-2012 10:21 PM
I have just sent a ticket request.
Thanks.
