**** Very Slow Seed Can Someone Help Pls :( ***
moshint
hi, need some help please. getting very poor download speeds. done a bt speedtest , its on attachment . anyone pls advise Cry
Hary
Re: **** Very Slow Seed Can Someone Help Pls :( ***
Someone will be able to help if you can post your router stats
  Sync Speed
  Attenuation
  SNR Margin
  http://kitz.co.uk/adsl/frogstats.php
Also your current line speed ( PN profile)
jojopillo
Hi moshint,
Your current BT profile is 135k which means that due to some  intermittent connection and a poor sync rate your profile has been reduced. Can you plug into your test socket and come back to me so I can do another check?
Jojo Smiley
moshint
there is no master socketSad .
i tried loggong into the router and entered serial number from router but that failed.
speed is now dying. this cannot go on for much longer
Serriously thinking of cable
moshint
the support is as bad as the product itself. good riddance to rubbish. cable i miss you.
i will never recommend plus.net to anyone, where ever i post will only be my experience which is below "0". never have i ever come across a poor setup.
bye Angry
