Very Low SNR
- Very Low SNR
Very Low SNR
06-09-2014 3:58 PM
Should I be concerned if my SNR is very low?
It currently been reported at:
SNR Margin (dB): 2.8 5.8
Attenuation (dB): 66.5 39.3
Message 1 of 4
(623 Views)
3 REPLIES 3
Re: Very Low SNR
06-09-2014 4:12 PM
Mr flibble says while that is a little low as long as your not dropping connection you should be ok, just keep an eye on it, if it's constantly dropping low and your getting disconnections then i would report a fault.
Message 2 of 4
(449 Views)
Re: Very Low SNR
06-09-2014 4:31 PM
It looks as though you are on a 3dB default noise margin which is quite remarkable for that line length. You must have a very good line
If you aren't seeing a lot of disconnection leave well alone as you are getting the best speeds possible
Message 3 of 4
(449 Views)
Re: Very Low SNR
06-09-2014 5:11 PM
Thanks for the replies.
Yeah my net is pretty solid although not very fast, 2.1Mb 😕
Message 4 of 4
(449 Views)
