Ventrilo 3.0 (Port 3211)
- Ventrilo 3.0 (Port 3211)
15-11-2007 9:36 PM
I've checked its not an issue on my end by forwarding any relevant ports, not that this was necessary before, but still tried with no success.
I have raised a ticket with no reply for over 24 hours now which is pretty slow so thought i'd post here.
Is it possible that plus.net are somehow shaping the data or slowing it down? I have pinged the IP address and run tracerts outside of ventrilo which show a steady 40-50 ping, however when on ventrilo itself, when connecting to port 3211, it says 5000+ ping.
Any help appreciated, cheers.
Matt
Re: Ventrilo 3.0 (Port 3211)
15-11-2007 9:37 PM
15-11-2007 9:41 PM
over a maximum of 30 hops:
1 2 ms 2 ms 2 ms 192.168.1.1
2 21 ms 25 ms 35 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 37 ms 26 ms 21 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 30 ms 21 ms 30 ms LINX1.LON-2.uk.lambdanet.net [195.66.224.99]
5 40 ms 38 ms 45 ms FRA-1-pos313.de.lambdanet.net [82.197.136.25]
6 41 ms 37 ms 42 ms FRA-3-eth100.de.lambdanet.net [217.71.96.70]
7 42 ms 44 ms 51 ms NUE-2-eth100.de.lambdanet.net [217.71.96.74]
8 41 ms 42 ms 52 ms lambdanet-gw.hetzner.de [213.239.242.214]
9 40 ms 41 ms 40 ms hos-bb2.juniper1.rz4.hetzner.de [213.239.240.140
10 43 ms 40 ms 54 ms et.1.16.rs3k9.rz5.hetzner.de [213.239.244.40]
11 57 ms 46 ms 58 ms static.88-198-26-240.clients.your-server.de [88.
198.26.240]
Trace complete.
15-11-2007 9:41 PM
16-11-2007 6:06 PM
I'm currently looking into this as there's a couple of people reporting issues, I've raised it as an internal problem (47948), so far checking the flows for yourself the traffic is being picked up correctly, are you using a different server now to when it was a problem?
Plusnet Technology
17-11-2007 3:11 PM
17-11-2007 3:14 PM
87.117.195.90:4234
17-11-2007 6:23 PM
port 4333 here - can post more if needed.
18-11-2007 2:37 PM
When i was on sky we always had this it was the vent servers playing up - it happened for so long we moved over to teamspeak in the end, as vent was just too unstable
18-11-2007 4:00 PM
Anyway, I still have an awful, unusable ping during Plusnet peak time. Please fix asap as its going my head in.
Obviously something has changed in the Vent traffic and plusnet isn't giving it priority since version 3 went live.
18-11-2007 4:37 PM
18-11-2007 7:13 PM
Going through the PLusnet guide to wireshark, it does look like Ventrilo 3 packets are being identified as Bronze traffic, which would explain the bad ping.
18-11-2007 8:46 PM
19-11-2007 5:52 PM
Net Ops have made the changes I asked them to do. Live monitoring shows we are matching flows with the new signature.
FYI - you will need to disconnect/re-connect to your ventrilo server.
20-11-2007 10:42 AM
It was much better last night.
