Vast Improvement To My Speed And Ping
Steve
Seasoned Pro
Just as the title says really,this is what my line should be like at all times so lets hope it does stay like this and i will be pleased once more,2 things i did do was..
1.de-activated my surf/Your Surf Access is currently Unrestricted
2.disconnected from internet then re-connected.
Gateway im on now is.You are currently connected to the "City Lifeline, Juniper 8" gateway. This gateway is sometimes known as pcl-ag01. Plusnet Premuim.
Of course it its 05.48 at time of posting this but im very happy with my ping and well the speed is what i should be getting anyway.
If life gives you lemons, make lemonade.
volta84
Re: Vast Improvement To My Speed And Ping
Yes much better now than earlier lol
By the way if my connection doesnt Sync at 8128kbps Should I keep disconnecting and retrying until it does? Its dropped to 7k odd now and never normally is.
Volta,
repeated disconnections can cause the Dynamic Line Management to increase your target noise margin (resulting in lower sync) so don't be tempted to keep trying for a faster sync.  Normally the best thing is to try once during daylight (as noise is usually lower and you should get a better sync for a given noise margin), waiting an hour or so after it becomes light is recomended, if you don't get a good sync on the first attempt then wait a while before trying again (if your sync is not too bad then waiting until the next day is probably wise), it's better to have a day on a slightly lower sync than to get your speed knocked down by the DLM.
Call me 'w23'
reserved
Fixes: 4
Looking much better today for me too !
6550Kbps & 54ms pings
Just hope it lasts this time !!!  Cheesy
volta84
errrrrrr, i rebooted my router just now and get this!?
Steve
Seasoned Pro
Still keeping good connection and great pings this afternoon,will see if its like this this evening between 10pm and 12am.
HaydnExport
yup, i'm well happy with mine too ,  Cool
tobykim
reserved
fingers crossed  Smiley
Fixes: 143
Not just fingers Wink Smiley
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
reserved
If you say so  Grin
Steve
Seasoned Pro
Be afraid...Be very afraid...im on the same gateway as my original post and look at the state my lines becoming,and this is before the dredded 10pm-12am..
btharper
My speed is still just a poor:
Ping is getting worse too.
Theo
Fixes: 143
Gateway pcl-ag03
Gateway ptn-ag1
