Do you mean
Vanishing green cabinets
Re: Vanishing green cabinets
what's your postcode, I'll check on the December spreadsheet for you.
it'll tell you if your scheduled for FTTC and what cabinet your on.
NN17 1RD ?
@millsdon
Good news, your scheduled, and it would seem you can get it already, Corby went live a few weeks back IIRC - 12th March according to the Twitter feed.
SAU_ID Name Postcode SAU_NODE_ID Exchange Only Flag Percent Lines Uplift Phase Deployed FTTC or FTTP
EMCRRBY CORBY NN171RD {EMCRRBY}{P32} 0 100% 3.22 7b Yes FTTC
Using a random house from street view for your postcode the BT WHolesale checker shows:
For Address 36 CUPAR CRESCENT, CORBY, NN17 1RF on Exchange CORBY
Your exchange is ADSL enabled, and our initial check on your address indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our check also indicates that your line currently supports an estimated ADSL Max broadband line speed of 6Mbps; typically the line speed would range between 5Mbps and 8Mbps.
Our check also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 11Mbps; typically the line speed would range between 6.5Mbps and 15Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1Mbps and downstream line speed of 11Mbps; typically the downstream speed would range between 6.5Mbps and 15Mbps.
Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 36.5 Mbps and upstream line speed of 5.9 Mbps.
PS: Your on cabinet 32
where is cabinet 32? is it on a google map?
thank you.....
Thanks for that. I do hope BT do come up with FTTP otherwise there are going to be a hell of a lot of unhappy people on my end of the estate.
Quote from: Ronski
@glloyd, bad news, your either on a direct exchange line or P16, either way they are not scheduled for FTTC or FTTP
EAWTH WITHAM CM82SZ {EAWTH}{M_D} 1 88%
EAWTH WITHAM CM82SZ {EAWTH}{P16} 0 11%
BT may implement some form FTTP for exchange only lines, though thats only wispers at the moment.
Damn annoying when mods keeping moving established threads that then get lost.
I agree, far to much rubbish in the Broadband thread, it urgently need splitting
Quote from: Ronski
PL12 6TD, if someone could check id be grateful
Also, if fibre is going to come to my exchange soon under the superfast cornwall scheme I'm guessing it would be simply a matter of keeping PN as my ISP and just placing a fibre order with them?
Hi steveng4237, your not on a cabinet, your line is direct to the exchange, so can't be enabled for FTTC. I believe quite a lot of Cornwall is going to get FTTP, which is better, and this has also been mentioned for exchange only lines as well.
You may be able to find out more here http://www.superfastcornwall.org/ the other place to ask is on the http://forums.thinkbroadband.com/fibre.html forums.
Quote from: Ronski
You have started it now  Cheesy
Can you check mine please?  TA6 5PD
@theberrys
WWBWAT BRIDGWATER TA65PD {WWBWAT}{P45}       0           100%          5.8 6bf Yes             FTTC
Your on cabinet 45, which is scheduled in phase 6bf, whenever that is/was. Superfast where and when gives a ready for service date of June 2012, although this may well change.
PS Deployed means scheduled.
Please bare in mind this data is from December and may well have changed by now.
Quote from: Ronski
Thanks for your time, much appreciated
Quote from: Ronski
if you'd have a look at mine I'd be grateful, I can't get any answers anywhere else ~ TR14 7BP
@joncooper
Your on one of three cabinets, two scheduled for FTTP, and one for FTTC
WWCAMB CAMBORNE TR147BP {WWCAMB}{P17} 0 20% 5.48 Cornwall - Tranche 2 YES FTTP
WWCAMB CAMBORNE TR147BP {WWCAMB}{P19} 0 77% 4.69 Cornwall - Tranche 2 YES FTTC
WWCAMB CAMBORNE TR147BP {WWCAMB}{P39} 0 2% 9.76 Cornwall - Tranche 2 YES FTTP
No way to tell which one your on, it's not always the closest, have you tried your number or address into the BT ADSL Checker? http://www.dslchecker.bt.com/adsl/adslchecker.welcome Note: If your number is not recognised, make sure you did not enter a space, if it's still not recognised try your adress, not just your post code.
Chances are your on P19 as that supplies 77% of the lines in your postcode, but of course you could be on either of the other two, only BT knows which one.
According to http://www.samknows.com/broadband/exchange/WWCAMB FTTC is available in some areas. I posted a link a few posts back for Cornwall, may be worth looking on there.
Bare in mind this information may have altered since December.
Edit: I just tried some random house numbers on the BT wholesale checker forGWELMOR from google maps for your postcode, and the lower the house number the faster the FTTC speed estimate, so it looks like you may be able to get it, unless your on one of the FTTP cabinets.
